Go to Post It truly is a Merry Vexmas! - Ginger Power [more]
  #16   Spotlight this post!
Unread 08-01-2011, 21:18
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: Communicating with Feeder
Originally Posted by Trent B View Post
A little more looking into it it appears as long as you don't exceed the breakdown voltage (which is the voltage you have to reach before you can start to conduct in reverse, it shouldn't get damaged. Something to dig out the spec sheets for.
Yup.
This website has some useful info...
Of particular interest might be the "Tri-Color" LED section...
http://www.kpsec.freeuk.com/components/led.htm
  #17   Spotlight this post!
Unread 08-01-2011, 21:23
ChristopherBuck's Avatar
ChristopherBuck ChristopherBuck is offline
FRC #0612
ChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the roughChristopherBuck is a jewel in the rough
Originally Posted by Tanis View Post
I will personally bake cookies for any team that utilizes semaphore to communicate with their feeder.
For those of you unfamiliar with semaphore, I would recommend checking out Monty Python's semaphore Wuthering Heights.
Well, the Analyst would have a set of free hands...
EDIT: <T25> seems to prohibit flags for this purpose, but maybe they could just do the signals without the flags?
EDIT2: <T26> seems to indicate flags or similar devices would be allowed, depending on the interpretation of said devices not communicating with anything or anyone outside of the arena
  #18   Spotlight this post!
Unread 08-01-2011, 21:28
The Lucas's Avatar
The Lucas The Lucas is offline
CaMOElot, it is a silly place
AKA: My First Name is really "The" (or Brian)
FRC #0365 (The Miracle Workerz); FRC#1495 (AGR); FRC#4342 (Demon)
The Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond reputeThe Lucas has a reputation beyond repute
Send a message via AIM to The Lucas
I like the idea of robot LEDs to indicate which tube you need. You could even use a FIRST Logo sticker and insert the colored LEDs into the logo.
Before suggesting ways to communicate between the Alliance Station and the Feeder Station, please read Section 5.5.7 Special Equipment Rules of the Manual It is one of those sections that people rarely read and then they have to be told not to wear Bluetooth headsets in the Arena.
Electrical & Programming Mentor ---Team #365 "The Miracle Workerz"
Programming Mentor ---Team #4342 "Demon Robotics"
Founding Mentor --- Team #1495 Avon Grove High School
2007 CMP Chairman's Award - Thanks to all MOE members (and others) past and present who made it a reality.
Robot Inspector
"I don't think I'm ever more ''aware'' than I am right after I burn my thumb with a soldering iron"
  #19   Spotlight this post!
Unread 08-01-2011, 21:34
Trent B Trent B is offline
College Mentor
AKA: Trent Borman
no team (Surviving Grad School)
Trent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to beholdTrent B is a splendid one to behold
Send a message via AIM to Trent B Send a message via Yahoo to Trent B
The bi-color ones intrigued me however they are a few bucks a piece on digikey compared to tri-color being about a buck a piece.
A consideration with the tri-colour is how the fact you have the common cathode that would somehow have to switch sides if you wanted to run it off a spike switching direction.
Additionally blue and red LEDs run at different voltages so you have to factor in resistors and how to potentially run it off a single spike. The nice part about two sets using the diode breakdown voltage is you can use a single spike and a little breadboard rather than potentially two spikes.
I suppose you could hook up one color to the positive on the spike, one to the negative and the cathode to the negative on the power distribution board.(provided there isn't a rule against this, because it wouldn't be protected by a circuit breaker as those are only on the red blocks) You could also have it merge in with the spikes negative which may violate rule R43) below.
Originally Posted by R43
Custom circuits shall NOT directly alter the power pathways between the battery, PD Board, speed controllers, relays, motors, or other elements of the robot control system (including the power pathways to other sensors or circuits). Custom high impedance voltage monitoring or low impedance current monitoring connected to the ROBOT'S electrical system is acceptable, because the effect on the ROBOT outputs should be inconsequential.
Former 2502 (Talon) Captain and 3928 (Neutrino) Mentor, currently teamless and attending Penn State for graduate school.
Have questions about Iowa State University or Penn State University? Feel free to email or PM me
  #20   Spotlight this post!
Unread 08-01-2011, 21:35
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Use a laptop to flash the color fullscreen
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
  #21   Spotlight this post!
Unread 08-01-2011, 21:38
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
Yes. This seems to be the most effective way.
...And when it isn't flashing full-screen color, it shows random pictures of funny kittens to distract the other team!
  #22   Spotlight this post!
Unread 08-01-2011, 21:44
HumblePie's Avatar
HumblePie HumblePie is offline
AKA: Mista Doug
FRC #3489 (Category 5)
Rookie Year: 2010
HumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really niceHumblePie is just really nice
Holy cannoli, keep it simple folks! The analyst has 2 free hands, 2 simple sets of red/white/blue cards or a 3-sided color-coded signalling post will allow communication with both Feeders. Don't we have TWO robots to build?
  #23   Spotlight this post!
Unread 08-01-2011, 21:45
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Another idea for a low tech system, just a simple poster that the analyst would hold up signaling which shape and which side to load on, similar to the play calling cards that Oregon uses in NCAA football like this: http://media.spokesman.com/photos/20...52 f96b62dbc7
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
  #24   Spotlight this post!
Unread 08-01-2011, 21:59
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
I would say using LEDs are the best option. Seems like a lower chance of getting the desired game piece wrong.
  #25   Spotlight this post!
Unread 08-01-2011, 22:08
bassoondude bassoondude is offline
1293 Awards and Rules Captain
AKA: Miller
FRC #1293 (D5 Robotics)
Team Role: Leadership
Rookie Year: 2010
bassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to beholdbassoondude is a splendid one to behold
Another low tech option would be to have the analyst hold up their right arm for one color, left for another, and both for the third. the exact colors can be decided before a match
2011 Palmetto Regional: Semi-Finalists
2010 Palmetto Regional: Semi-Finalists
2009 Palmetto Regional: Quaterfinalists
  #26   Spotlight this post!
Unread 08-01-2011, 22:10
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
One thing to consider when making a decision on this is that you don't know what feeder you're actually going to be talking to. Even if you have a teammate as a feeder, you might need to bail on his side of the field and go for the other side. I think you really should assume you're always communicating with a complete stranger, that you MAY have talked with before a match.
Also, how, exactly, are you going to accurately direct your communication at a particular feeder? If they both have robots incoming, how are you going to communicate with both simultaneously? And will they see you behind a plexi wall and a rack full of logos? And do you want them to be concentrating on your signalperson across the field, or the incoming robot?
Just a few things to think about before you settle on LEDs or other robot based signaling methods.
  #27   Spotlight this post!
Unread 08-01-2011, 22:16
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Originally Posted by smistthegreat View Post
... just a simple poster that the analyst would hold up signaling which shape and which side to load on, similar to the play calling cards that Oregon uses in NCAA football...
It's been said more than a few times, but READ THE MANUAL!
In this case, see
Originally Posted by The All-revealing FRC Game Manual
<T25> The only equipment that may be brought on to the ARENA is the OPERATOR CONSOLE,
reasonable decorative items, and special clothing and/or equipment required due to a
disability. Other items, particularly those intended to provide a competitive advantage for
the TEAM, are prohibited.
Signaling items are definitely illegal.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #28   Spotlight this post!
Unread 08-01-2011, 22:20
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Light up your robot either blue, red, or white. One thing I have learned from watching drivers and being on the drive team: you all will be looking at the robot and not each other most of the time so use the robot as the messenger. It will also make dealing with HP's from other teams a whole lot easier since you are never guaranteed your human player will be putting tubes in or always be going to one side of the field.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
  #29   Spotlight this post!
Unread 08-01-2011, 23:15
FRC #0612
Originally Posted by StevenB View Post
It's It's been said more than a few times, but READ THE MANUAL!
In this case, see
Ah, it may seem so, but read on.
I believe the legality of signaling cards, flags, paper, etc. depends upon the interpretation of <T26>
Originally Posted by T26
Devices used solely for the purpose of tracking strategy of hame play are allowed inside the ALLIANCE STATION, if they meet ALL of the following conditions:
  • Do not connect to the OPERATOR CONSOLE
  • Do not connect to or attach to the FIELD or ARENA
  • Do not connect to or attach to another ALLIANCE member
  • Do not communicate with anything or anyone outside the ARENA.
  • Do no include any form of enabled wireless electronic communication (e.g. radios, walkie-talkies, cell phones, Bluetooth communications, WiFi, etc.)
  • Do not in any way affect the outcome of a MATCH, other than by allowing TEAM members to plan or track strategy for the purposes of communication of that strategy to other ALLIANCE members.
  #30   Spotlight this post!
Unread 08-01-2011, 23:33
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
Based on T26, it seems legal to bring a signaling device to the driver's station.
