Go to Post Could you post your code? It is hard to debug that which you cannot see... - Dusk Star [more]
Unread 08-01-2011, 23:19
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2010
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Mini-bot Ideas
I've noticed that out of the 7 Mini-bot threads started so far, not a single one's purpose is to discuss the actual ideas, designs, and prototypes for making and deploying Mini-bots. So, without further ado, please feel free to post your ideas, no matter how ludicrous.
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 08-01-2011, 23:49
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: Mini-bot Ideas
LOL JK
I think really strong magnets should do. Just launch it up from the base of the pole.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 08-01-2011, 23:50
mcrawford mcrawford is offline
Zac Efron-461
FRC #0461 (West Side Boiler Invasion)
mcrawford is an unknown quantity at this point
Re: Mini-bot Ideas
duke how do like that sounds pretty ludicrous
Unread 08-01-2011, 23:52
ENIAC's Avatar
ENIAC ENIAC is offline
AKA: Matthew Petersen
FRC #5958 (Blue Wave Robotics)
Team Role: Coach
ENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the roughENIAC is a jewel in the rough
Re: Mini-bot Ideas
I have to say, the last one they showed, the one with two wheels that are pulled against the pole by a weight, would be good, but placed on the pole, not moved out there by it's own power. A simple system of microswitches and latches should be sufficient.
Unread 09-01-2011, 14:35
RevonZZ
Posts: n/a
Re: Mini-bot Ideas
One thing that really must be cleared before we begin designing our bots is wether we need to keep it up or just trigger the sensor at the top.
If I was given unlimited parts and access beyond the FTC parts I'd suggest a minibot propelled by small single burn rocket motors, replaced every game. That thing would fly.
Unread 09-01-2011, 14:45
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Mini-bot Ideas
You only need about 4 newtons to trigger the target, no need to destroy the sensor.
Unread 09-01-2011, 15:37
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: Mini-bot Ideas
i think the plan with my team is to use the main robot to "Launch" the minibot, rather than have it move under its own power. it should work alright. i also think that our mini-bot wont have any electrics, entirely potential energy driven.
Unread 09-01-2011, 20:13
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: Mini-bot Ideas
Sorry, but I don't believe the rules will allow that.
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous. Violation: The TOWER on which the MINIBOT is DEPLOYED is disabled. If the MINIBOT is not deployed on a TOWER, then the ALLIANCE’s TOWER upon which the highest RACE SCORE was earned will be discounted.
The parts to allow you to make the Minibot must follow this rule:
<R92> The following items are the only permitted materials for use on the MINIBOTS:
A. TETRIX components,
B. no more than two motors (PN W739083),
C. exactly one 12V rechargeable NiMH battery pack identical to those supplied in the FTC kit of parts (PN W739057)
D. No more than one HiTechnic DC motor controllers,
E. No more than one NXT controller with the Bluetooth functionality disabled,
F. Polycarbonate,
G. Polycarbonate glue,
H. Aluminum sheet, 90° angle, u-channel, tube, bar,
I. rivets,
J. non-metallic rope or cord,
K. wire nuts,
L. cable ties,
M. limit switches,
N. no more than two common household light switches,
O. wire of appropriate gauge (see Rule <R40>),
P. non-slip pad,
Q. PVC or CPVC pipe,
R. PVC cement or cleaner,
S. Mechanical hardware (i.e. screws, bolts, etc) ,
T. Loctite or similar thread-locking product,
U. Rubber bands,
V. Surgical tubing,
W. Electrical tape and shrink tubing,
X. PWM extension cables,
Y. Universal security clips to hold the PWM connectors together,
Z. Hook and loop fastener (may not be used as tape), and
AA. Magnets.
Obviously we are very early in the build season, so I'm certain refinements to the rules will make it clearer if your idea will work or not.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 09-01-2011, 20:40
JohnHorton's Avatar
JohnHorton JohnHorton is offline
Shock Test Dummy
FRC #1100 (Tomahawks)
Team Role: Electrical
JohnHorton will become famous soon enough
Re: Mini-bot Ideas
In response to my previous post, I figured out the initial launch velocity needed.
Assuming:
-Kinetic minibots are allowed
-4N triggers the switch (as indicated in GM 2.2.5)
-A section of PVC around the tower with some hinging and latching weighs in at 120g
-The target switch takes 1 cm to trigger
-Friction turns off for the day
The initial launch velocity would need to be 7.5 m/s.
I rounded up gravity to 10 m/s^2 and rounded up most of my numbers to two sig. figures.
This is on the outside for that weight of PVC. I think +/- .5m/s would be fine, depending on friction.
The tall guy in the camouflage hat.
John Horton
Unread 09-01-2011, 22:43
Mr_I's Avatar
Mr_I Mr_I is offline
AKA: Tom Indelicato, 811 Moderator, Mentor, Parent, ...
FRC #0811 (Cardinals)
Team Role: Teacher
Mr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant futureMr_I has a brilliant future
Re: Mini-bot Ideas
I'm trying to convince my team to consider using Ytivarg to make the minibot climb the tower.
(Hint - Lleps ti sdrawkcab! )
"It's NOT Just A Robot Thing!"
Unread 10-01-2011, 00:22
itsalka's Avatar
itsalka itsalka is offline
FRC #3070 (Pronto)
Team Role: Mechanical
itsalka is an unknown quantity at this point
Re: Mini-bot Ideas
Our team's thinking of having a minibot with two plastic clips (like the bottom spring on an umbrella http://www.umbrellaman.co.uk/UserFil...n-Umbrella.jpg ) that would both have a curved side towards the pole, and then would maybe be attached to some PVC so the robot could lock on. However, having looked at the rules some more, I think it would be hard to make them/have them work without using springs. If anyone knows what I'm talking about, do you have any ideas?
Unread 10-01-2011, 10:29
dsmith14469 dsmith14469 is offline
FRC #1511
dsmith14469 is an unknown quantity at this point
Re: Mini-bot Ideas
Something our team learned is that the sensor that needs to be triggered is 3 limits switches wired in series positioned around the circle. So launching an item my trigger only one switch and no the other two in which case no score.
Unread 12-01-2011, 22:34
blackrocks0 blackrocks0 is offline
AKA: Chaitanya Chittineni
FRC #2264 (Inceptus)
Rookie Year: 2010
blackrocks0 is an unknown quantity at this point
Re: Mini-bot Ideas
I'm sure that the robot has to move under its own power after the first 18 inches of the pole. (also sure you can't use springs)/.
Unread 12-01-2011, 22:39
wilsehn wilsehn is offline
FRC #2996
wilsehn is an unknown quantity at this point
Re: Mini-bot Ideas
didn't read everyones but the robot has to be self driven-that means no springs or rocket boosters the general sensus seems to be that putting the robot on the pole is quicker than having it drive off the 'hostbot' so likewise it would be good for teams to have a deployment system that does not require the mini to drive.
  #15   Spotlight this post!
Unread 13-01-2011, 19:17
FatBabyJezus's Avatar
FatBabyJezus FatBabyJezus is offline
IczyG
FRC #2204
Team Role: Webmaster
FatBabyJezus is on a distinguished road
Re: Mini-bot Ideas
Hmm. How about utilizing magnets, like a maglev train?
Use the magnets to attach to the steel pipe, then flip a switch and propel it to the top?
Would it work?
I love the world.
Go humans.
