Go to Post I firmly believe that it's within your power to aspire instead of lament. - Alan Anderson [more]
Unread 09-01-2011, 01:29
bobosalad's Avatar
bobosalad bobosalad is offline
FRC #2518 (Spartans of St. Jude)
Team Role: Driver
bobosalad is an unknown quantity at this point
Defense v Offense
i started looking at the design and am having disagreements with teammates about the strategy of going about this design. his idea is to go and build a defensive robot that has the mini robot as well with no lift. i disagreed and said we need the lift. what are your opinions of defense v offense? is there really a defense this year? can defense be played with an offensive robot?
Unread 09-01-2011, 01:35
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Re: Defense v Offense
I haven't done any calculations yet about the rate of point scoring and strategy (let the game sink in for the weekend), but the general rule of thumb is that defensive bots only work well if your teammates can score. You also have to take into consideration just how wide this field is, as one robot cannot stop 3 attackers that easily, only slow them down, if at all.
Attending: MN Duluth Regional
Koko Ed's Avatar
Koko Ed Koko Ed is online now
Serial Volunteer
AKA: Ed Patterson
FRC #0191 (X-Cats)
Take the California FIRST philosophy with this game:
The best defense is a good offense.
Unread 09-01-2011, 02:05
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
Team Role: Mechanical
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
I believe mini bots are going to be a HUGE part of this game. If your robot will be able to play defense effectively and have a great mini bot, then this isn't a bad idea. You'd need to be able to hold your ground. It is true defense is limited this year with the pinning rule and no entering scoring zones, but defense will still be key. You could also block people from coming out of their lanes when they go and get their tubes. However, you have to score to win the game. If you can have both an effective tube manipulator and mini bot, offense is most likely the best strategy.
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 09-01-2011, 02:18
bobosalad's Avatar
Team Role: Driver
would people agree that generally, if you build a good offensive robot, it could still be used purely for defense if the occasion arises?
Unread 09-01-2011, 02:22
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
As someone who played through Triple Play (2005) game, where massive penalties simply from a minor driving mistake could easily swing matches, you better be extremely careful going on a primarily defense-robot route this year. The 1x penalties from home zone and lane incursions, as well as the 10x penalty for pinning means your team really has to walk a fine line without racking up penalties for your alliance.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 09-01-2011, 02:51
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Molten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond reputeMolten has a reputation beyond repute
Though it isn't the popular opinion, defense wins matches. Yes, you have to score something in order to win...but you don't have to score alot. You just have to score more then your opponents. I've always wanted to be on a defense-planned team(usually end up on a defense-improvised team). I think a team that has a good traction, maneuverable, fast drive train with a good driver and good mini bot would be nearly unbeatable. Admittedly, this sounds like a tall order, but if you cut out the manipulator you can put all of your weight into drive/mini bot.
Anyone can do defense, but only some can do it well enough to win with it. If you go in planning on offense, your probably not going to win by falling back to defense(Buckeye 2007 was a semi-exception for 1766 since we did make it to pick our own alliance with an improvised defense robot). If you want to do defense right, plan on doing defense. Every pound you spend on a semi-working manipulator could be used elsewhere more effectively.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 09-01-2011, 10:38
578robotsrock's Avatar
578robotsrock 578robotsrock is offline
I belive robots rock!
AKA: Erich
FRC #0578 (Red Raider Robotics)
Team Role: Leadership
Rookie Year: 2010
578robotsrock is on a distinguished road
IF you can play defense well, you'll do good. Last year we put all our focuse on having a bot with manily defense and a decent kicker to clear balls. We didn't win any compositions besides an off season one, but we played on Saturday afternoon and even when we were ranked near last because of allence pairings in qulification matches, we were pulled forward to play. We are still in planning now, but I would vote for a similar staigy of making a mainly defensive robot that has some sort of scoring capabilities, either mini-bot or a claw.
I BELIEVE THAT ROBOTS ROCK
Unread 09-01-2011, 10:54
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Rookie Year: 2010
Ryan_Davis is an unknown quantity at this point
Ah remember the regional . You, Penfield, and ourselves. Yay malfunctions.
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 09-01-2011, 10:58
GGCO's Avatar
GGCO GGCO is offline
AKA: Grant
FRC #3357
GGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to beholdGGCO is a splendid one to behold
Send a message via AIM to GGCO
Any robot with four wheels can be a defensive bot. It's that simple.
I think a minibot is a must have though, so personally if it came down to a sweet manipulator or a crazy fast minibot - I'd take the minibot hands down.
"Great spirits have always encountered violent opposition from mediocre minds" - Albert Einstein
The FIRST Alliance
COMETS Robotics
Website
Unread 09-01-2011, 11:08
dodar's Avatar
dodar dodar is offline
FRC #1592 (Bionic Tigers)
Rookie Year: 2007
dodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond reputedodar has a reputation beyond repute
Sorry Bomb Squad, you cant play defense. =] lol
1592(Student and Mentor) 2007-2012
Blue Banners: 2008 Colorado, 2012 Orlando, 2012 South Florida, 2014 Orlando, 2015 Buckeye
Mechanical Engineering - University of Central Florida(Class of 2016)
Unread 09-01-2011, 11:32
1168Programmer 1168Programmer is offline
Head Programmer/CEO
FRC #1168
Team Role: Student
1168Programmer is an unknown quantity at this point
Partly, it can come down to your budget. If you have the money to make an awesome arm that works every time, then go for it, you'll be a valuable assert on every alliance.
It also depends on what type of wheels you're going to use. (Or maybe its the other way around.) Omni would make terrible defense but the manuverability would make amazing offense. KOP wheels could probably do either depending on how you build the bot.
BuzzMathias175's Avatar
BuzzMathias175 BuzzMathias175 is offline
Team Member
FRC #0175 (Buzz)
BuzzMathias175 is an unknown quantity at this point
The only defensive tactic I could see is "traping" an opposing robot in their End zone preventing them from leaving it to get more tubes to score
Unread 09-01-2011, 13:38
Head Programmer/CEO
FRC #1168
Team Role: Student
Or even just getting in the way out in the middle of the field. (You know, that awkward you-go-this-way-no-that-way thing when you almost walk into someone.) A few seconds of distraction could cost the opponent alliance a completed top row logo, definitely worth it. At least, as long as you can't do anything else to help your alliance score crazy amounts of points.
  #15   Spotlight this post!
Unread 09-01-2011, 13:34
Head Programmer/CEO
FRC #1168
Team Role: Student
Any robot with four wheels can be defensive, but not every robot with four wheels can be effectively defensive.
