Go to Post My own opinion is that any truly great student can succeed with any teacher, and any truly great teacher can succeed with any group of students. - DampRobot [more]
View Poll Results: Mecanum or 6WD
Mecanum 90 40.36%
6WD 133 59.64%
Voters: 223. You may not vote on this poll
Unread 09-01-2011, 15:48
Charmander's Avatar
Charmander Charmander is offline
None #1714
Rookie Year: 2010
Charmander can only hope to improve
Mecanum or 6WD
So my team has had a big debate between Mecanum and 6WD. 6WD is ideal for transporting tubes from one side of the field to the other because of the potential speed, while Mecanum is ideal for placing tubes on the scoring grid due to the lateral movement. We are allowed to "throw" the tubes to the center. This ability supports Mecanum because it shortens the distance of travel. However, this will cause an increase in robot to robot contact to which mecanum wheels are not well equipped for due to low traction. We have heard a lot of hype about the 6WD on the forums.
Questions:
6WD or Mecanum? Which do you prefer and why?
What is the turn radius of 6WD?
Do you predict the game to be high contact or not? Why?
Unread 09-01-2011, 16:01
Ryan_Davis Ryan_Davis is offline
FRC #3157 (Iron Lancers)
Rookie Year: 2010
Ryan_Davis is an unknown quantity at this point
Re: Mecanum or 6WD
Questions:
I think Mecanum seeing as it brought success for us last year, the turn radius can't be that good for 6WD not to mention the extra power expended in turning those two extra wheels. Then again Mecanum requires four motors. I predict we will see robots shatter. I liked that at the kickoff.
"Quality means doing it right when no one is looking."
-Henry Ford
Unread 09-01-2011, 16:03
Rookie Year: 2010
Re: Mecanum or 6WD
The rules state that four motors is max just fyi.
-Henry Ford
Unread 09-01-2011, 16:14
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
BrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond reputeBrendanB has a reputation beyond repute
Re: Mecanum or 6WD
You can have a max of 4 cims plus the motors included in the kop.
I would go with 6wd over mecanum in a heartbeat. Mecanums as mentioned have no pushing power and you won't be driving as fast around the field either. One problem with throwing the tubes to the center is you are increasing the chance for your opponents to grab it especially if you are the weaker drive. Yes there is some advantages with the lateral movement in front of the rack, but I'd take speed and pushing power over that.
A properly built 6wd and 8wd will have a turn radius of zero and waste no power.
1519 Mechanical M.A.Y.H.E.M. 2008 - 2010
3467 Windham Windup 2011 - 2015
1058 PVC Pirates 2016 - xxxx
Unread 09-01-2011, 16:22
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Re: Mecanum or 6WD
6wd is the best because, not only is it faster and has more power, it can even be considered more manuverable than a mecanum. We tested this with our previous robots it takes 4 seconds with 6wd and 11 seconds with mecanum.
Unread 09-01-2011, 16:51
BIGWILLI2081's Avatar
BIGWILLI2081 BIGWILLI2081 is offline
FRC #2081 (Icarus)
Team Role: Mechanical
BIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of lightBIGWILLI2081 is a glorious beacon of light
Re: Mecanum or 6WD
to do what?
2011 Boilermaker Regional Champions
2011 Boilermaker Motorola Quality Award
2011 Boilermaker Autodesk Excellence in Design Award
2010 Boilermaker Regional Finalists
2009 Boilermaker General Motors Industrial Design Award
2008 Boilermaker Engineering Inspiration Award
2007 Boilermaker Rookie All-Star Award
Unread 09-01-2011, 18:25
Rookie Year: 2010
Re: Mecanum or 6WD
The rules say:
<R45> Motors specifically permitted on 2011 FRC ROBOTS include:
A. all motors, actuators, and servos listed in the 2011 KOP Checklist,
B. an unlimited number of COTS servos with a maximum power rating of 4W ,
C. one or two CIM motors in addition to
those provided in the KOP. This means up to four CIM motors and no more can be used on the robot
-Henry Ford
Unread 09-01-2011, 22:02
AKA: Brendan Browne
Re: Mecanum or 6WD
The rules say:
Exactly! I was replying to someone who stated that only 4 cims can be used on the robot and only the four no other motors.
Unread 09-01-2011, 16:02
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Mecanum or 6WD
6WD - higher traction, less weight, simplicity, comes in the KoP!
Turning radius - of a properly designed 6WD should be zero, it should turn around the center point of the robot the weight should be relatively centered on the robot.
Yes - after seeing 2007
Edit:
Simplicity because of less gearboxes, another plus is less weight because of that same reason.
Turning radius - see above
Extra power - this is a misnomer. The same amount of power would be going to the ground, in fact in mecanum, there is wasted power because the force vectors work to cancel another wheel's. A 6WD should also require 4 CIMs.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 09-01-2011, 16:11
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
Re: Mecanum or 6WD
This does not waste any power.
The only wasted power in a mecanum is due to the friction in the bearings in the rollers.
Unread 09-01-2011, 16:13
Chris is me's Avatar
AKA: Pinecone
Re: Mecanum or 6WD
I think he means in the sense that part of the force "cancels out" as it's applied in a direction the robot is not travelling in.
Unread 12-01-2011, 01:43
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Mecanum or 6WD
Even with a frictionless roller, you're wasting power by squeezing or stretching carpet in the sideways direction while trying to move forward or back. You could perhaps argue that this isn't being wasted "in a mecanum", but it's definitely happening because of features inherent in a mecanum wheel.
Unread 09-01-2011, 16:04
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Mecanum or 6WD
It would be helpful if you could explain some of your assumptions:
Why do you assume Mecanum slower? Atleast, it isn't slower in forward and reverse.
Also, why would "throwing tubes" to the center give the advantage to mecanum? Assuming that you would go pick them up again, which is what I think you mean, how is it quicker?
To answer your question, a dropped center 6wd can turn with 0 turn radius.
To those above, can you cite a rule that says you can only use four motors?
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 09-01-2011, 16:06
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Mecanum or 6WD
Mecanum has less traction, which will be key in this game. A good defender should be able to lock down the scoring zones--unless there are two robots attacking at once.
What would you say is a properly designed 6WD? With the middle wheel lower than the others in West Coast style?
  #15   Spotlight this post!
Unread 09-01-2011, 16:16
Re: Mecanum or 6WD
A little definition: West coast drive means that the wheels are cantilevered (unsupported on one end). 6WD is usually implied that the middle wheel is lowered (usually between 1/8" and 3/16"). A way around this is to have equal diameter omni wheels on the outer wheels.
You can use 4 CIMs <R45c> plus the rest of the motors in the kit of parts <R45a>, there's a special section about the RS motors (you can use up to four in any combo, even duplicates) <R45d)
My bad, you're right.
James Tonthat
