| View Poll Results: Mecanum or 6WD | |||
| Mecanum |
90 | 40.36% |
| 6WD |
133 | 59.64% |
| Voters: 223. You may not vote on this poll | |||
Mecanum or 6WD
So my team has had a big debate between Mecanum and 6WD. 6WD is ideal for transporting tubes from one side of the field to the other because of the potential speed, while Mecanum is ideal for placing tubes on the scoring grid due to the lateral movement. We are allowed to "throw" the tubes to the center. This ability supports Mecanum because it shortens the distance of travel. However, this will cause an increase in robot to robot contact to which mecanum wheels are not well equipped for due to low traction. We have heard a lot of hype about the 6WD on the forums.
Questions: 6WD or Mecanum? Which do you prefer and why? What is the turn radius of 6WD? Do you predict the game to be high contact or not? Why? |
Re: Mecanum or 6WD
Re: Mecanum or 6WD
The rules state that four motors is max just fyi.
Re: Mecanum or 6WD
You can have a max of 4 cims plus the motors included in the kop.
I would go with 6wd over mecanum in a heartbeat. Mecanums as mentioned have no pushing power and you won't be driving as fast around the field either. One problem with throwing the tubes to the center is you are increasing the chance for your opponents to grab it especially if you are the weaker drive. Yes there is some advantages with the lateral movement in front of the rack, but I'd take speed and pushing power over that. A properly built 6wd and 8wd will have a turn radius of zero and waste no power. |
Re: Mecanum or 6WD
6wd is the best because, not only is it faster and has more power, it can even be considered more manuverable than a mecanum. We tested this with our previous robots it takes 4 seconds with 6wd and 11 seconds with mecanum.
Re: Mecanum or 6WD
to do what?
Re: Mecanum or 6WD
Re: Mecanum or 6WD
Exactly! I was replying to someone who stated that only 4 cims can be used on the robot and only the four no other motors.
Re: Mecanum or 6WD
6WD - higher traction, less weight, simplicity, comes in the KoP!
Turning radius - of a properly designed 6WD should be zero, it should turn around the center point of the robot the weight should be relatively centered on the robot. Yes - after seeing 2007 Edit: Simplicity because of less gearboxes, another plus is less weight because of that same reason. Quote:
Extra power - this is a misnomer. The same amount of power would be going to the ground, in fact in mecanum, there is wasted power because the force vectors work to cancel another wheel's. A 6WD should also require 4 CIMs. Last edited by James Tonthat : 09-01-2011 at 16:06. Reason: Reply to above post |
#10
Re: Mecanum or 6WD
The only wasted power in a mecanum is due to the friction in the bearings in the rollers. |
#11
Re: Mecanum or 6WD
I think he means in the sense that part of the force "cancels out" as it's applied in a direction the robot is not travelling in.
#12
Re: Mecanum or 6WD
Even with a frictionless roller, you're wasting power by squeezing or stretching carpet in the sideways direction while trying to move forward or back. You could perhaps argue that this isn't being wasted "in a mecanum", but it's definitely happening because of features inherent in a mecanum wheel.
#13
Re: Mecanum or 6WD
It would be helpful if you could explain some of your assumptions:
Why do you assume Mecanum slower? Atleast, it isn't slower in forward and reverse. Also, why would "throwing tubes" to the center give the advantage to mecanum? Assuming that you would go pick them up again, which is what I think you mean, how is it quicker? To answer your question, a dropped center 6wd can turn with 0 turn radius. To those above, can you cite a rule that says you can only use four motors? Last edited by Jeffy : 09-01-2011 at 16:08. Reason: to add |
#14
Re: Mecanum or 6WD
Mecanum has less traction, which will be key in this game. A good defender should be able to lock down the scoring zones--unless there are two robots attacking at once.
What would you say is a properly designed 6WD? With the middle wheel lower than the others in West Coast style? |
#15
Re: Mecanum or 6WD
You can use 4 CIMs <R45c> plus the rest of the motors in the kit of parts <R45a>, there's a special section about the RS motors (you can use up to four in any combo, even duplicates) <R45d) My bad, you're right. |
