Re: capping the tower
The round tubes have a diameter of 12" and are flexible, the disks at the top of the poll are 12" too. This means that potentially the disk could fall down the to the bottom.
1) Field reset will want to do mean things to you. They have to remove the tubes. 2) If I were the head ref, I'd see intentional blocking. Boom, red card. See that blue box below <G24>? It's not a rule, but it does say something about throwing tubes at minibots climbing. I'd figure on that being enough to pull the card; you are interfering with deployment. |
if it was done, i'd assume the same rule for minibot would apply, you got them on, you have to get them off. |
If you do something during teleop and you can't be called for that action in the endgame, boy will there be a lot of pins when the lights start flashing. It's a deliberate action taken to prevent a minibot from climbing. The rule does not say, In the End Game, you can't interfere with deployment/climbing. It says, You can't interfere, with no time limit given. So if I slam an Ubertube over your post's target autonomously, and it interferes with minibot deployment (which it probably will), and I don't get a red card, you're going to be in the question box explaining to the ref that you couldn't deploy because I slammed an Ubertube over your target. (In that case, I'd also get a penalty. But I might view the penalty as minor compared to the race points.) Deliberate interference=red card. |
RE: SteveGpage. Human player may only offer robot a tube via the designated slot. It can't be tossed into the arena over the player station.
I'm tired of quoting the manual for today so all I will say is "Try again".
See <G57>
Obviously safety does play a big factor into this kind of thing, but if this is foreseen an update should clarify it if the GDC does indeed to believe it to be a safety issue. Otherwise the field reset people should have a ladder. Also, I am not agreeing nor disagreeing with this idea (which I do think is a good idea, if it proves legal) but discussing this specific point. |
#10
