Go to Post But really, FIRST attracts all kinds of people; nerds, geeks, dorks, preps, techies, PR people, financial persons, etc. - Dorienne [more]
Unread 09-01-2011, 21:32
shawnz shawnz is offline
Flamewar Initiator
FRC #0907 (E. Y. Cybernetics)
Rookie Year: 2007
shawnz will become famous soon enough
Addressing the scoring pegs
Have you guys come up with regular ways of addressing the scoring pegs? Off the bat we've been using A-F for columns and 1-3 for rows, but we were thinking it might make more sense to address the columns by right/left grid as well as triangle/circle/square column.
IMO, it's pretty important to get this standardized right away, just because I foresee feeders having to signal these addresses to drivers across the field in a pinch, and they may not necessarily be on the same team as each other.
Unread 09-01-2011, 21:46
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Addressing the scoring pegs
What about them are you asking about addressing?
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 09-01-2011, 21:51
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Their position, as in a grid.
Things that would need to be standardized are:
Their horizontal position
Their vertical position
Where do you start? Top left? Bottom left? Whose perspective?
Unread 09-01-2011, 21:53
Flamewar Initiator
Rookie Year: 2007
as in, a way of providing each scoring pin with an address to reference them by.
Originally Posted by Vikesrock View Post
I would think that the coach/drivers should be signaling the feeder what they want, not the feeder telling them where to put things.
well, yeah. the feeder might have a better view of the grid than the driver, though, but of course the opposite could easily be true as well.
Unread 09-01-2011, 21:56
AKA: Carl Springli
Rookie Year: 2010
So are you referring to the fact that the manual does not specify what the heights of the pegs are at all? I mean it says adjacent pegs will not vary by more than 8 inches, but that's a lot of potential variance and we cannot build an accurate field or array of pegs without knowing the height of the pegs. Also, would it be the same between different events?
I think that they want to get more teams using the camera to locate field elements, such as the reflective tape. Our programmers seemed confident they could do this, but integrating the hanging of a tube with the recognition of the reflective tape will still present a challenge.
If they don't change the heights at all at individual events or between events, we could find heights that work and stick to those...
Unread 09-01-2011, 21:49
Vikesrock's Avatar
Vikesrock Vikesrock is online now
Team 2175 Founder
AKA: Kevin O'Connor
Rookie Year: 2007
Unread 09-01-2011, 22:00
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Agreed. We are planning on putting lights on the robot to indicate which one we want.
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 17-01-2011, 21:18
woogit's Avatar
woogit woogit is offline
1778 ALUMNI 4434 ALUMNI
AKA: Emilie Woog
no team (Chill Out)
Rookie Year: 2007
woogit is an unknown quantity at this point
Have you found that lights are legal? Both my team and a sister team are thinking that using lights would be illegal as per R02 C and R15. We have started thinking about using something like a rotating card that had the three colors and only displayed one at a time, so that we wouldn't interfere with light sensors.
"We have a marketable hooker."
Dean's List Finalist 2010
Unread 17-01-2011, 22:53
SteveGPage's Avatar
AKA: Steve
I would think the only thing we would have to worry about, would be <R02> C, and we would have to make sure the lights don't, in any way, mimic the vision targets. <R15> doesn't apply, since it wouldn't be a "non-functional" decoration. It would certainly have a designed function. I guess we should ask the GDC about R02, though.
Thanks!
SteveGPage's Avatar
AKA: Steve
We had the same thought. We thought about using this approach with having an Analyst. I drew up a quick diagram with the letters across the top, the numbers down the side, and the preferred symbol grayed out in the box. That way the Analyst, who can be keeping track of what game pieces have been played can say "We need a white circle in B1." We thought we would label them A-F from left to right as the teams are looking at the field. I will do a mock up of the form shortly.
Steve
Unread 09-01-2011, 22:01
Flamewar Initiator
Rookie Year: 2007
Steve
yeah, exactly. the role of the analyst almost alludes to having to set up something like this.
other things to consider: is 3 the bottom, or the top, which would be more consistent with the scoring? is 6 letters too many to mentally sort while you're in the middle of driving (hence breaking it up into L/R grid as well)?
indeed -- we were going to try this as well (assuming they don't somehow make it illegal, but i don't see how they could or why they would)
Unread 09-01-2011, 22:08
SteveGPage's Avatar
AKA: Steve
Good question. While the scoring amounts could be used to reference the row, since we're not calling it "the 3 point row" I think that it would be ok to call the top row "1" - but am okay with it either way.
As to the letters, it is probably because I am a (very) frequent flier - A to F works for me, since that is the standard lettering designation on six seat rows!
Steve
Unread 09-01-2011, 23:30
Siri's Avatar
Siri Siri is offline
Dare greatly
AKA: 1640 coach 2010-2014
no team (Refs & RIs)
Team Role: Coach
Rookie Year: 2007
Siri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond reputeSiri has a reputation beyond repute
Send a message via ICQ to Siri
Good thoughts. As far as human player-to-coach communication, some sort of sign(s) might be useful. Lunacy (with much simpler communication) had problem enough with less obscured vision.
If we're talking alliance station communication, my initial thought was "Left 1-3" and "Right 1-3". Less ambiguous, but longer to say. A-F seems good too, and likely not too much to process. Frequent fliers or not, most English speakers know without thinking that the first 3 letters are A, B and C. That splits it in half, leaving only 3 choices each again.
As for heights, I'd imagine low/mid/high or bottom/mid/top would catch on quickly. Not sure I understand the need to use numbers for those, especially if there's going to be hesitation on whether to count up or down.
Unread 09-01-2011, 23:52
SteveGPage's Avatar
AKA: Steve
You would be surprised how many people think their E seat is MY aisle seat!
As for "low/med/high" I agree doesn't have any ambiguity, but is saying "A high" or "b low" or "c medium" clear in the chaotic mess of a match? We tend to hear things like "b low" as "below" or "c medium" as "see medium", and may pause to say "below what?" or "see the what?" - where as "A1", etc ... registers as a matrix location, since it is an alphanumeric combination, rather than phonetic sounds. My thought was to supply a physical sheet with the matrix and symbols on it to every member of the alliance, so by the time the match starts everyone should be clear on the meanings. Having said that, I am still not married to this approach and would encourage other thoughts or ideas! I will post the document up in the morning and put a link on this thread so everyone that is interested can review and comment.
Thanks!
  #15   Spotlight this post!
Unread 10-01-2011, 00:00
AKA: Carl Springli
Rookie Year: 2010
How about "High Circle Left" or "Low Square Right", assuming u exclusively wish to place pieces where they would help your alliance in completing a logo.
