Go to Post 71% efficiency is best efficiency. ;) - Chris is me [more]
Unread 09-01-2011, 21:57
Tbush173's Avatar
Tbush173 Tbush173 is offline
AKA: Travis Bush
FRC #0173 (RAGE)
Team Role: Mechanical
Tbush173 is on a distinguished road
Possable strategy for high ranking points
Hello, I am a FIRST Alumni who is now mentoring my former team while attending college. (Just thought I'd introduce myself as I've never been very active on Chief Delphi) Anyways, I was scrutinizing this years game manual when I discovered a strategy that may help both alliances in a match when it comes to gaining ranking points. For those who don't know, your ranking score is determined by the losing alliances score. The winning alliance receives the losing alliances score before penalties, and the losing alliance receives their own score after penalties. Now this is intended to encourage teams to not play defense on the opposing alliance as their score could determine your rank. I think we can take it a step further and have both alliances help each other out so that both alliances can receive high scores and the winner/loser will be irrelevant as the win/lose record has no bearing on your rank.
Now, the layout of the field is such that your alliances scoring zone is right in front of your drivers station, and your feeder station and towers are on the opposite side of the field. This will tend to create a collision zone in the center of the field where robots from either alliance will have to navigate past each other in order to get to their respective feeder stations. The only other option is to throw the tubes from the feeder station as far as you can to your own scoring zone and hope that your robot gets to it before your opponents do.
I have an alternate strategy that will change everything. Talk with your opposing alliance and make the following agreement: to have your alliance's feeders feed tubes to the opposing alliance. I can think of no reason why anyone would not accept this agreement. If you tell your feeders to feed tubes to your opponents and your opponents decide not to feed tubes to your side, that would only mean that they win, but receive your alliances low score as ranking points due to the fact that they had no tubes to hang. If both sides tell their feeders to feed tubes to the opposing alliance, then both scores will be higher than if feeders feed tubes to their own alliance. Even if you lose, your ranking score will still be higher than if your hadn't made the agreement.
Edit: Sorry, this is not a viable strategy as Win/lose record determines your rank ahead of ranking points. I apologize for any confusion this may have caused.
Unread 09-01-2011, 22:00
Grim Tuesday's Avatar
Grim Tuesday Grim Tuesday is offline
AKA: Simon Bohn
FRC #0639 (Code Red)
Rookie Year: 2010
Grim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond reputeGrim Tuesday has a reputation beyond repute
Re: Possable strategy for high ranking points
Are you sure you aren't reading the 2010 manual? This year is Win-Loss-Tie.
Or am I feeding the trolls?
ATannahill ATannahill is online now
AKA: Alex Tannahill
ATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond reputeATannahill has a reputation beyond repute
I see a big red light on this idea.
Teams are first sorted by qualification points. You get 2 for winning, 1 for tieing and 0 for loseing. Ranking points are there to break ties.
- Arizona North
Unread 09-01-2011, 22:03
Sean Raia's Avatar
Sean Raia Sean Raia is offline
Curious spectator & alumn
Sean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond reputeSean Raia has a reputation beyond repute
Teams may end up doing this, but i think the judges/other teams may frown upon this. It doesn't seem like the spirit of FIRST to me.
Edit: Whoops, looks like it wouldn't work anyway.
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
This is all based on the false presumption that your your rank is determined by your ranking score. It is determined by your qualification score. Ranking score is what you are talking about. Qualification score is 2 points for a win, 1 for a tie, 0 for a loss. Ranking Score is the tie-breaker.
[2016-present] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 09-01-2011, 22:05
Tbush173's Avatar
AKA: Travis Bush
FRC #0173 (RAGE)
I appolagize for this tread, I should have read the manual more thourghly.
Unread 09-01-2011, 22:06
Robert103's Avatar
Robert103 Robert103 is offline
Rob Small
FRC #0103 (Cybersonics)
Team Role: Scout
Robert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to beholdRobert103 is a splendid one to behold
Send a message via AIM to Robert103
It should stay in the back of your mind though that defense during qualification matches may not be as important as in finals matches. Letting the other alliance score during qualifications may be a good thing, if only to break the tie, of course.
ahollenbach ahollenbach is offline
AKA: Andrew
Rookie Year: 2010
ahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to allahollenbach is a name known to all
Check out 5.3.3 and 5.3.7
In summation, they state that qualification ranking is first and foremost obtained via a 2 point win, 1 point tie, and 0 point loss. The team with the highest number of points will be seeded first.
If there is a tie (e.g. two times have 4 wins, 2 ties and 0 losses, totaling 10 qualification points), then it goes to Ranking Score, which is what you are talking about. So it is helpful to avoid the other alliance, to an extent.
Unread 09-01-2011, 22:07
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Team Role: Teacher
Rookie Year: 1999
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
<G33>Neither ROBOTS, HOSTBOTS, nor MINIBOTS may break the planes of the vertically projected borders of the opponent’s LANES.. Violation: PENALTY
You can't enter, reach over, or get near the other teams FEEDER STATIONS.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 09-01-2011, 22:11
Tbush173's Avatar
AKA: Travis Bush
FRC #0173 (RAGE)
I actually meant that the feeders could throw the tubes into the opposing alliances scoring zone, but the strategy is not viable anyways because win/lose record determines rank before ranking points
