Go to Post From what I've seen in FIRST, teams that copy generally always learn something from it, and if they don't, the copy they produce is of much lower quality than the original. - TheOtherGuy [more]
Unread 09-01-2011, 22:51
darkorbit's Avatar
darkorbit darkorbit is offline
Electrical?!
AKA: Jin Lem
FRC #0069 (HYPER ROBOTICS)
darkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to alldarkorbit is a name known to all
classmate question
When in the Driver side of the classmate is the dashboard suppose to close when you click on Remote Dashboard? I'm not too sure why it closes the dashboard when I click on Remote Dashboard. When I click Local Dashboard the Dashboard loads. I'm just wondering is this normal?
2007 BOSTON REGIONAL WINNERS (NU-HYPER-FORCE)
2008 Florida Regional 2nd Place
Unread 09-01-2011, 23:01
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: classmate question
If you're forwarding Dashboard data to a different computer, the local Dashboard display on the Driver Station computer will not show anything useful. I agree with the design decision to close that display when it is not in use.
Unread 09-01-2011, 23:03
darkorbit's Avatar
Electrical?!
AKA: Jin Lem
Oh I see so it is normal for the dashboard to close when I click on remote dashboard because it is not being used. Am I correct?
