Go to Post FIRST, for me, is about mental wrestling with oneself through the ideas of others and learning through this dialogue. - sammyjalex [more]
Unread 10-01-2011, 12:04
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Support Robot Concept
lets say that a robot sits in its lane against the feeder station and is built in such a way that it can launch tubes across the field similar to track balls being launched in Overdrive.
The strategy is not to score but to make it very easy for your teammates too
in theory your entire aliance will spend the majority of the match inside a safe zome.
Prototype: Tip a tube any shape so that it is perpendicular to the feeder slot and then punt it with your foot. It can fly above other robots and land in your zone.
Note: not hitting poles might take some engineering but shouldnt be that big of an issue.
Unread 10-01-2011, 12:08
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Re: Support Robot Concept
Considering most teams will probably have some sort of large appendage capable of going upwards, the support strategy you suggest may not work very well.
If you do happen to make a robot capable of flinging tubes with great accuracy across the field, it will only take a raised arm or lift to "stuff" the shots you are taking across the field.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 10-01-2011, 12:14
BrianT103's Avatar
BrianT103 BrianT103 is offline
AKA: Brian Taylor a.ka. BT
FRC #0103 (Cybersonics)
BrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud ofBrianT103 has much to be proud of
Send a message via AIM to BrianT103
This is a neat idea.
Launching tubes that are 3 different shapes 54 feet across the field into your home zone consistently is a big challenge. There are a couple reasons why this would work as well as why it wouldn't.
Here's why it would work:
1. Because opponents aren't allowed in your loading station, your launches won't get blocked by opposing teams.
2. The area in which the tubes must land is pretty big (17' by 8' iirc). Allows for a significant margin of error in terms of flight trajectory, etc.
Here's why it won't work:
1. Opposing teams can raise their towers and sit in front of the opposing team's home zone knocking down any launched tubes.
2. Even though teams have the ability of extending outside of the frame perimeter this year, designing a device to hurl a lightweight tube 55 feet is no small task. The force required would be substantial.
Unread 10-01-2011, 12:20
Chris is me's Avatar
AKA: Pinecone
I like the idea of a robot that has an arm at exactly the height of the lane loader that goes from the lane, grabs a tube, then brings it to the midfield and "passes" it to a teammate. However, the rules currently prohibit robots taking tubes from other robots.
Unread 10-01-2011, 12:27
Patrick Chiang Patrick Chiang is offline
Programming
FRC #3070 (Team Pronto)
Patrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to allPatrick Chiang is a name known to all
Thought that rules would only apply for opponents. Like, if you pin your own teammate, there wouldn't be a penalty, right?
Unread 10-01-2011, 12:32
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
Team Role: Coach
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Love the idea but i think i see 2 problems with it. I do not see the tubes making all the way across the field(maybe you can roll the round ones). The second is the pipe for the end game would get in the way. But more power to you. I would love to see it in action if you guys build it.
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 10-01-2011, 12:36
AKA: Pinecone
Sadly, no. I'm hoping it's an oversight that will be corrected in an Update.
<G49> ROBOTS may not attempt to POSSESS a GAME PIECE that is being POSSESSED by another ROBOT. Violation: PENALTY
Unread 10-01-2011, 12:29
I can kick it the full length of the field and reach a height of approximately 15 feet. another proof of concept is that robots could throw the much larger and much heavier trackballs 7 feet in the air.
so one or two of there robots will have to block our zone, which would mean that they are not scoring which I think I would still be ok with
accommodating the different sized tubes wouldn't be that difficult.
yes there are some design challenges but I think they can be overcome.
Unread 10-01-2011, 12:33
Josh Goodman's Avatar
Josh Goodman Josh Goodman is offline
The Voice of WNY
FRC #1511 (Rolling Thunder)
Josh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond reputeJosh Goodman has a reputation beyond repute
The idea of a feeder robot is solid. Basically in it's simplest form, the feeder robot's job is to either gather tubes from the field or from its own human player and drop them in the alliances scoring safe zone. This allows your big scorers for nonstop scoring.
Now, the best way to do this IMO is literally hanging onto game pieces and moving super fast so that no matter what, the game piece will always be in the possession of your alliance.
Like this launching method (if it worked) it might be faster, but it's easily defended. Teams would recognize this and you would not be picked because of it. So I do think the feeding option is excellent, but launching tubes I don't think is the best way of going about it.
Josh Goodman
Mentor and Volunteer
Team 1511: Rolling Thunder
joshuapgoodman@gmail.com
Unread 10-01-2011, 12:38
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
This is assuming that your scorers will be able to pick up off the ground. I think that's a pretty big assumption.
Unread 10-01-2011, 13:24
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
It might be... but if you can't pick them up off the floor, you're stuck driving to the other side to get game pieces every single time. That's a pretty big handicap to have, considering past experiences of game pieces littering the floor.
Unread 10-01-2011, 14:00
It may not be as easy to block, but it will still certainly be reasonable to block shots. If a team with a 10 foot arm is standing even at the end of the lane line, it will require a pretty decent arc to launch a tube over them.
-Brando
Unread 10-01-2011, 14:13
OK they block the lane with a 10 foot arm, the robot can still drive across the field to supply another team or move out of the way and shoot. Even still forcing a team that can score to block a team that can't is still worth it.
I am kind of surprised so many people are ruling this idea out...
Unread 10-01-2011, 14:28
The shooting concept is probably being ruled out because its quite a challenge to undertake. Can it be done? I'm sure it can, and probably will be this season, but it's still a large challenge, and risk, that many teams probably do not want to take.
The idea of bringing tubes across the field is perfectly legitimate, and I'm sure many teams will be able to do this quite successfully. However, many teams may have this functionality built in to their design just by having an arm capable of loading quickly and driving fast.
Unless theres a specialized mechanism, the idea of a support robot seems more like a strategy than a design concept.
-Brando
  #15   Spotlight this post!
Unread 10-01-2011, 18:40
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Is there a distinct advantage to this more than just having the feeder throw the tubes over the wall instead of putting them through the slot?
<G57> During the TELEOPERATED PERIOD, FEEDERS may enter LOGO PIECES onto the FIELD by using the FEEDING SLOTS or by throwing the LOGO PIECE over the top of the FEEDER STATION wall.
I've heard credible reports of being able to reach half-field, and that's without much practice.
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
