Go to Post "What connection is the most vital to the success of your robot?" The one between the drivers brain and hands, and the one between the coaches brain and mouth. None of the other ones matter if those two don't work. - dlavery [more]
Unread 11-01-2011, 07:17
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Re: Logomotion Scorer Android App
Originally Posted by Tanis View Post
Hallry- What method are you using to install the apk? When you say it doesn't work at all, do you mean that it doesn't load at all, you see a black screen, it force closes, or you see the correct screen but can't do anything?
By it doesn't work, I mean that whenever I try to download the file it says 'download unsuccessful,' and that the 'content is not supported.'
Unread 11-01-2011, 07:39
darist darist is offline
AKA: David Aristizabal
darist is an unknown quantity at this point
You probably don't have an app that supports .zip files.
I know of a couple of ways around this:
1. You can download the .zip file to your computer, extract the .apk file from it, then put it on your phone's SD card. Then from the phone you have to find that .apk file to install the app. I imagine you could also email the .apk file to yourself if you don't want to go through the trouble of connecting the phone to transfer the file over USB.
2. You can download an app on your phone that handles .zip files. I used ES File Explorer (free in the market). When you download the zip file, it opens with that app. You use the app to extract the .apk file. Then you navigate to the dir where the file was extracted and tap it to install it.
good luck
Unread 11-01-2011, 07:58
Got latest version. Looks like the "ubertube counter" is now reset when you clear the grid through the menu option. But maybe it's not decremented when you clear a peg with an ubertube using the long-tap.
Example:
Place three ubertubes on grid
place other game pieces on pegs with ubertubes
clear one of the pegs with an ubertube - using long-tap
try to add ubertube to any peg: you get the "too many ubers" error message.
Thanks again... this is a pretty cool app!
Unread 11-01-2011, 08:00
Hallry's Avatar
Dare to be FIRST
AKA: Ryan Hall
Rookie Year: 2010
good luck
Thank you very much, I'll try the second option after I get out of school later. I'll cross my fingers!
Unread 10-01-2011, 23:47
Works well on my droid x, not rooted.
Thanks!
