Go to Post I can't believe that I said the CD community could be patient - in December. - JaneYoung [more]
Unread 11-01-2011, 19:55
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
Rookie Year: 2000
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
Re: How fast r u gonna go?
From the last 11 years of seeing a lot of different drive trains, I have to say practice makes one of the biggest difference in ability of drivers to handle speed.
In Overdrive, we used 4 CIMS with a 7:1 reduction using the AM Stackerbox with an ackerman steering, which seemed to work really well, we approximated our drive speed to around 22fps.
Last year, we went a completely opposite direction and designed an 8 wd using 8" skyway wheels, we were an even match for even some of the lowest geared robots. It all depends on whats appropriate for competition. This year on a flat field I see advantages to a 2 speed transmission in gaining speed but I dont think it will help with anything if the drivers cannot learn the change the speeds well on the fly. The shifters now have gotten far better than they were a few years ago.
Team 56 2000-2007 (Student/Vol.)
Team 2016 2008 - ??? (Mentor)
Unread 11-01-2011, 20:08
team 3311 team 3311 is offline
FRC #4057 (Klamath Basion Robotics)
Team Role: Leadership
team 3311 has a spectacular aura aboutteam 3311 has a spectacular aura about
here's and idea try making a programing shiter aka dumb down your contlers imput values then have a easy byttion to go to full speed
Unread 11-01-2011, 20:09
here's and idea try making a programing shiter aka dumb down your joysticks imput values then have a easy byttion to go to full speed
Unread 11-01-2011, 21:00
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Well, the reason most folks use a shifter is to have a LOT of pushing power and what you are suggesting will just slow it down.
Bruce
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 11-01-2011, 00:18
lbarger's Avatar
lbarger lbarger is offline
Senior LRI NC District
AKA: Lee Barger
FRC #0587 (The Hedgehogs)
lbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud oflbarger has much to be proud of
Re: Don Don Don
Originally Posted by Bruceb View Post
Don Don Don... I have the motor curves and I have the JVN design calculator.
I know the free speed is 5500 rpm. I am not an engineer. I don't know how to figure what I can realistically expect the CIMs to be turning at at nominal load at speed. Sorry, my calculus is nonexistent, I never had physics and I am just trying to help some kids build a robot. Now, if you are willing to help, great.
Bruce
Bruce, I find it better to think about how fast the robot SHOULD go than trying to target a specific speed and working out the gear ratio. What is often not mentioned is the fact that all drive motors run through circuit breakers that limit current to 40 amps. If you look at the CIM motor you will see that it's stall current is more like 130 amps. If you stall the motors, you will trip the breakers. If you trip the breakers you are not moving until they reset.
I encourage my team therefore to design the robot so the wheels will slip before the motor current exceeds 40 amps. To do this requires knowledge, or reasonable estimates, of both robot's weight and the coefficient of friction from the wheels.
It will take too long to describe the process in detail here. I have given a presentation on this subject and send it if you PM me with contact information.
The short version (which will likely not help without a background in engineering or physics) is that you need to determine the torque required at the wheel to cause slippage as well as the available torque from the motor at or below 40 amps. The ratio of the two gives you the desired maximum gear ratio. Each stage of gear reduction (gear, sprocket or pulley) could be roughly estimated to reduce the maximum motor speed by roughly 95%. Most gear boxes have 2 stages of gears and then chain to drive the wheels (0.95^3 is about .85). So the speed of the robot SHOULD be something like (motor free speed)*(~0.85 efficiency)*((motor torque at 40 amps)/(wheel torque for slippage))*(wheel circumference). Of course it gets more complicated with multiple motors, multiple wheels and such. Generally safe to assume symmetry and that one or two motors drive half the robot weight for tank or skid steer drive trains.
Now I've probably gone and scared anyone from asking for the 'long' version.
As I said, contact me and I can break it down into manageable size bits of information.
