Go to Post I'm absolutely certain that kids prefer scoring points to not scoring points - AdamHeard [more]
Unread 10-01-2011, 19:56
Brandon_L Brandon_L is offline
The color orange triggers me
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Height of PVC pole in team version of tower
I can't seem to find the length of the pvc pole in the team version of the tower for the minibot. Does anyone know it?
FRC 2495 - Hamilton West Robotics [2007-2014]
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 10-01-2011, 20:24
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
Re: Height of PVC pole in team version of tower
I think you're suppose to not make it out of PVC,the real piece is 1 1/2" EMT (conduit) that you should be able to find at Home Depot or Lowes. It's 120" for reference.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 10-01-2011, 20:30
AKA: Brandon Liatys
Rookie Year: 2007
In the version for teams to build in the shop, low cost, its listed as just "Pole" so I took a guess that it was PVC as almost everything else was. Thanks!
Unread 10-01-2011, 20:37
KevinGoneNuts's Avatar
KevinGoneNuts KevinGoneNuts is offline
AKA: Kevin
FRC #0675 (Tech High Robotics)
KevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud ofKevinGoneNuts has much to be proud of
well it would just be best for the minibot if it was the same material as what it would be in the actual competition fields. the differences in friction could be an important factor.
Unread 10-01-2011, 21:31
CalTran's Avatar
CalTran CalTran is offline
Missouri S&T Senior
FRC #2410 (BV CAPS Metal Mustang Robotics)
Rookie Year: 2010
CalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond reputeCalTran has a reputation beyond repute
As well as the differences in friction, the minibots are, as I found more or less implied, supposed to use magnets to stay attached to the pole. Unless you have some super pvc, I don't think the same electromagnetic field applies.
Team 2410 thinks KISSing is amazing! Keep It Super Safe!
  • "You know you've been in robotics too long when you start talking to your tools." "Well, you've been in robotics CLEARLY too long when they start talking back"
  • Theory is when you know everything but nothing works. Practice is when everything works but you don't know why. On our team, theory and practice comes together - nothing works and nobody knows why.
MMR 2410 Student (2010 - 2013) | MMR 2410 Mentor (2013 - Present)
FTC Game Announcer / EmCee (2014 - Present) | FRC EmCee (2015 - Present) | FRC Referee (2016)
Academic Student (Forever)
Unread 11-01-2011, 09:35
GaryVoshol's Avatar
Cogito ergo arbitro
Rookie Year: 2000
Originally Posted by CalTran View Post
... the minibots are, as I found more or less implied, supposed to use magnets to stay attached to the pole...
That's one option that was given, not a mandate by any means.
(since 2004)
Unread 10-01-2011, 21:46
D.Allred's Avatar
D.Allred D.Allred is online now
FRC #4451 (Rat Rod Robotics)
D.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond reputeD.Allred has a reputation beyond repute
Brandon,
The team version of the tower uses the same material as the normal competition tower. Item #3 on drawing TE-11008 references a drawing from the competition game element drawing GE-11061.
The tower pole is a 10 foot 1-1/2" Steel EMT (aka electrical conduit). There are different types of steel conduit. Make sure you get "EMT."
Unread 11-01-2011, 09:37
Brandon Holley's Avatar
Brandon Holley Brandon Holley is offline
Chase perfection. Catch excellence.
AKA: Let's bring CD back to the way it used to be
FRC #0125 (NU-TRONs, Team #11 Alumni (GO MORT))
Brandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond reputeBrandon Holley has a reputation beyond repute
Send a message via AIM to Brandon Holley
Originally Posted by D.Allred View Post
Brandon,
This information is correct. The EMT conduit can be found at almost every Home Depot, Lowe's, or other various hardware stores.
-Brando
MORT (Team 11) '01-'05 :
-2005 New Jersey Regional Chairman's Award Winners
-2013 MORT Hall of Fame Inductee
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
2008 & 2009 Boston Regional Driving Tomorrow's Technology Award
2010 Boston Regional Creativity Award
2011 Bayou Regional Finalists, Innovation in Control Award, Boston Regional Finalists, Industrial Design Award
2012 New York City Regional Winners, Boston Regional Finalists, IRI Mentor of the Year
2013 Orlando Regional Finalists, Industrial Design Award, Boston Regional Winners, Pine Tree Regional Finalists
2014 Rhode Island District Winners, Excellence in Engineering Award, Northeastern University District Winners, Industrial Design Award, Pine Tree District Chairman's Award, Pine Tree District Winners
2015 South Florida Regional Chairman's Award, NU District Winners, NEDCMP Industrial Design Award, Hopper Division Finalists, Hopper/Newton Gracious Professionalism Award
Unread 11-01-2011, 11:16
team1512's Avatar
team1512 team1512 is offline
FRC #1512
team1512 is an unknown quantity at this point
diameter of pole in team version of tower
I am reading in several posts about a 1.5 od inch emt pole. It seems the drawings are calling for a 1.75 inch od. can anyone clarify. thanks.
Unread 11-01-2011, 12:00
Re: diameter of pole in team version of tower
You are looking for a 1.5" EMT pipe. The 1.5" is a pipe size that adheres to a set of regulations, but doesn't necessarily adhere to familiar fractional sizes.
Get 1.5" EMT pipe.
-Brando
Unread 11-01-2011, 13:57
Ryan Gordon Ryan Gordon is offline
FRC #2854 (EVHS Robotics)
Ryan Gordon is an unknown quantity at this point
Get 1.5" EMT pipe.
-Brando
To confirm if I was to measure a 1.5" EMT pipe, the O.D. would be 1.75"? (or roughly 1.75")
Unread 11-01-2011, 15:16
waialua359's Avatar
waialua359 waialua359 is offline
Mentor
AKA: Glenn
FRC #0359 (Hawaiian Kids)
Rookie Year: 2000
waialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond reputewaialua359 has a reputation beyond repute
Perhaps the updates will clarify the outside diameter.
A 1.5" EMT pole has a 1.9" OD.
As noted earlier in this post, there are references to something different. I would get clarification just to make sure.
2016 Hawaii Regional #1 seed, IDesign, Safety Award
2016 NY Tech Valley Regional Champions, #1 seed, Innovation in Controls Award
2016 Lake Superior Regional Champions, #1 seed, Quality Award, Dean's List
2015 FRC Worlds-Carver Division Champions
2015 Hawaii Regional Champions, #1 seed.
2015 Australia Regional Champions, #2 seed, Engineering Excellence Award
2015 Inland Empire Regional Champions, #1 seed, Industrial Design Award
2014 OZARK Mountain Brawl Champions, #1 seed.
2014 Hawaii Regional Champions, #1 seed, UL Safety Award
2014 Dallas Regional Champions, #1 seed, Engineering Excellence Award
2014 Northern Lights Regional Champions, #1 seed, Entrepreneurship Award
2013 Championship Dean's List Winner
2013 Utah Regional Champion, #1 seed, KP&B Award, Deans List
2013 Boilermaker Regional Champion, #1 seed, Motorola Quality Award
2012 Lone Star Regional Champion, #1 seed, Motorola Quality Award
2012 Hawaii Regional Champions #1 seed, Motorola Quality Award
Unread 11-01-2011, 15:54
D.Allred's Avatar
Glenn,
You have the wrong conduit. You have "rigid" conduit, not EMT. 1 1/2" rigid conduit has a thicker wall with an OD of 1.9".
Unread 11-01-2011, 18:40
waialua359's Avatar
Mentor
AKA: Glenn
Rookie Year: 2000
Glenn,
Sorry for the previous post.
I confused myself.
After re-reading the game manual and drawings, one section had it written as a pipe, which is why we weren't sure whether it was 1.74 or 1.9.
  #15   Spotlight this post!
Unread 11-01-2011, 15:18
You are correct.
See this website: http://www.home4c.com/conduit.htm
Scroll to the bottom to view EMT sizes.
-Brando
