Go to Post There's more than one way to skin a cat. - Al Skierkiewicz [more]
Unread 10-01-2011, 20:18
Wolfgang Wolfgang is offline
AKA: Mehmed
FRC #1245 (Shazbots)
Rookie Year: 2010
Wolfgang is an unknown quantity at this point
Field Technicality
Hey, I know I should feel really stupid about asking this, but the manual seemed unclear about it.
How high is the sensor on the minibot pole above the base?
If there is a resource I could use to find this information, that would be great as well.
Thanks!
Unread 10-01-2011, 20:22
Hallry's Avatar
Hallry Hallry is offline
Dare to be FIRST
AKA: Ryan Hall
FRC #1676 (Pascack Pi-oneers)
Rookie Year: 2010
Re: Field Technicality
Thanks!
As stated under section 2.2.5, The bottom of the lower disk (i.e. the portion of the TARGET contacted by the climbing MINIBOT) is approximately 122 inches above the floor., and the circular base is 12 inches tall. Therefore, 122-12, meaning that there are 110 inches between the two. Correct?
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
The manual is quite clear. Section 2 gives the height as 122" above the floor.
You could also find the info in the field drawings.
Ctl-F is the typical way to access a PDF reader's "find" feature, which may help find these.
(CD's search feature is in the orange bar, if you suspect someone else has asked the same or a similar question.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 10-01-2011, 20:28
AKA: Mehmed
Rookie Year: 2010
Thanks! That helps a lot! Didn't see that in the manual.
