Go to Post when all else fails, try making the bot go slower - KenWittlief [more]
Unread 10-01-2011, 21:47
RobotRaider RobotRaider is offline
Team Mentor
AKA: Eric
FRC #0461 (West Side Boiler Invasion)
Rookie Year: 2010
RobotRaider is an unknown quantity at this point
Rule <R11> "60 Inches" Max diameter?
Rule <R11> clearly states that the Maximum Horizontal Dimensions of Playing Configuration are 60" (213.4 cm).
1.) These don't match. 213.4 cm is 84" give or take.
2.) ^^ that being said, :in 2007 there was a similar rule that stated Maximum Horizontal Dimensions of Playing Configuration: 80" (213.4 cm). Which actually makes sense.
I'm sure this will come up in Q&A tomorrow. Just wondering if anyone has input or knows something new about this and what the likely outcome is.
Let's hope that it is the same rule as before: 80" (213.4 cm)
Thanks!
Unread 10-01-2011, 21:51
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Rule <R11> "60 Inches" Max diameter?
Yep, others have noticed it. There's already a 56-post thread going on here: http://www.chiefdelphi.com/forums/sh...ad.php?t=88589
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 10-01-2011, 21:59
Team Mentor
AKA: Eric
Rookie Year: 2010
So I see. heh.
Thanks for the info!
Unread 10-01-2011, 22:07
Bjenks548's Avatar
Bjenks548 Bjenks548 is offline
AKA: Brendan
FRC #0548 (Robostangs)
Bjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond reputeBjenks548 has a reputation beyond repute
question with the diameter. Could one end of the circle(60" or 80") be a robot bumper and the robot extend 60" or 80" from there or is the frame perimeter the center of the circle?
Toronto Regional quarter finalists. Northville Winners/ Chairman's Winners. Troy Finalist/ GM Industrial Design Award. Michigan State Championship Finalists. CMP Newton Division winners! Triple Balance count 13. Thanks to 1075, 4307, 67, 3656, 217, 2604, 2054, 245, 118, and 2194! Photo credit for my avatar Dan Ernst
Unread 10-01-2011, 22:10
vhcook's Avatar
vhcook vhcook is online now
Reader of Things
AKA: Victoria
FRC #1939 (Kuh-nig-its)
vhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond reputevhcook has a reputation beyond repute
The way this works is that if you were to draw an appropriately sized circle on the floor, and put the robot in it at full extension, the whole robot has to be inside the plane of the lines. You can back it up until the frame perimeter is up to but not over the lines - it doesn't have to be in the middle.
ETA: If you have multiple functions that are never ever used at the same time (such as an arm going forward and a minibot delivery system going backward), they don't have to fit at the same time - just in every configuration that will happen on the field.
