Go to Post Now I'm off to see the wizard, the wonderful wizard of Cogs. - Matt Krass [more]
Unread 10-01-2011, 21:59
Brandon_L Brandon_L is offline
Someone told me there was food here
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Rookie Year: 2007
Brandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond reputeBrandon_L has a reputation beyond repute
Ive got a problem with <R07a>
A. BUMPERS must provide complete protection of the entire FRAME PERIMETER of the
ROBOT (i.e. BUMPERS must wrap entirely around the ROBOT). As part of the 100%
coverage, BUMPERS must protect all exterior corners of the FRAME PERIMETER. For
adequate protection, a full segment of BUMPER must be placed on each side of the corner
(see Figure 3-2).
We had tons of ideas about manipulators such as a forklift, but how can you do that simply if you have to have a bumper on the front of your robot instead of a forklift?!?!
This rule puts complications in most of our arm designs too.
EDIT: Also, whats up with all the IMPI robotics images EVERYWHERE on CD
FRC 2495 - Hamilton West Robotics [2007-2014] - whats a..."hive mind"?
FRC 3929 - Atomic Dragons [2012-2013]
FRC 2180 - Zero Gravity [2017-]
Just trying to collect all the possible team colors
Unread 10-01-2011, 22:07
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: Ive got a problem with <R07a>
I know! And auto manufacturers have to follow all those arbitrary rules about mufflers and bumpers and seatbelts and all that. They could make cars LOTS faster and cheaper if they didn't have all these rules getting in the way!
Which is to say: Thems the rules. The GDC isn't in the business of making this EASY for you, after all. How fun would that be?
Unread 10-01-2011, 22:19
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
For a forkilift do what my team did in OverDrive... the two bottom fors were spring loaded to et them inside the bumper zone and went over the bumbers to have it flat on the ground.here are some pictures... look at before the match, and uring the match to see what i mean a botu spring loaded (orancge covers were spring on outside of white tubing)
http://photos.sabrerobotics.com/disp...album=45&pos=0
Unread 10-01-2011, 22:35
AKA: Brandon Liatys
Rookie Year: 2007
so we have to start inside the frame perim, but after the match starts we can unfold stuff to pretty much go over the bumpers, correct? (thus making them pointless..)
Unread 10-01-2011, 22:38
NorviewsVeteran's Avatar
NorviewsVeteran NorviewsVeteran is offline
Precision Driver Extraordinaire
AKA: Richard Raitt
FRC #1793 (Pilots)
NorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond reputeNorviewsVeteran has a reputation beyond repute
Have you read the rest of the rules?
______
I was in Scouts but I wanted out by the third meeting. I was in TSA, but I quit after a couple of weeks. I don't go camping with the SCA anymore. I was in taekwondo but I had to leave because I got sick.
I joined FIRST and stuck with it. It was nice enough to return the favor.
Unread 10-01-2011, 22:40
AKA: Brandon Liatys
Rookie Year: 2007
Most of them..
then you start thinking of designs and they get overcomplicated by so many rules haha
Unread 10-01-2011, 22:45
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Since you are calling it a lift, I'm going to assume that you then plan on lifting it up. In that case, once you lift it up, any collisions that you would have would be with the bumpers, not your frame. So they are not entirely pointless.
Also, this is a challenge that ALL TEAMS must overcome or deal with in some way, so it is not as though you are at a disadvantage because of the rule. There just need to be ways to make your ideas or ideas you have not yet thought of work with the placement of the bumpers.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 10-01-2011, 22:51
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
You ARE allowed to make a mechanism that extends outside of the bumpers and down in front of them. You would be responsible for any damage to the mechanism, but you could have your forklift. It would have to be a small one, though, as per the 60" cylinder rule.
Keep in mind that the GDC does do everything for a reason, even if they don't always explicitly explain it. Why are robots only allowed to be a maximum of 28"x38"x60" in starting configuration plus bumpers? To fit through doorways. Why must bumpers be constructed precisely according to the rules (i.e. using a specific thickness of wood, 2.5" pool noodles, having them in a SPECIFIC area etc)? To make sure that they're effective and uniform to all teams.
Can you think of a reason why the bumpers must protect 100% of the frame perimeter?
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
Unread 10-01-2011, 23:12
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Team Role: Leadership
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
If you can't go through it, go over it.
If you can't go over it, go under it.
If you can't go under it, get a new door.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
