Go to Post Having the ability, opportunity, and inclination to do manual labor makes you a better engineer. - MrForbes [more]
Unread 11-01-2011, 09:37
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Feeder Bot
Originally Posted by davidthefat View Post
Apparently throwing of any sort is out of the question for our team... They want full control of the tubes at all times.
The team realizes they will be in a variety of alliances with other teams, don't they? The longer the time before an actual event that the team comes to grip with the A-factor, the better their strategy will be. Just ask the team how they will convince an alliance team who thinks throwing will be OK.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 11-01-2011, 10:24
Techokami's Avatar
Techokami Techokami is offline
FRC #2122 (Team Tators)
Team Role: Mechanical
Rookie Year: 2010
Techokami is an unknown quantity at this point
Re: Feeder Bot
We do plan on throwing them in, as it would be faster than inserting them through the slot, however it's hard to get good accuracy or distance with the square and triangle.
Unread 11-01-2011, 10:50
mahumnut's Avatar
mahumnut mahumnut is offline
FRC #1418 (Vae Victus)
mahumnut is an unknown quantity at this point
Re: Feeder Bot
1418 discussed this as well, we tried throwing the pieces around and the only way we could get them to go anywhere with any sort of distance or accuracy was with a bunch of spin. Designing a mechanism to impart enough spin and launch it across the field length would be REALLY tough. We decided against it.
The other problem is you have to drive all the way across the field from the starting position to get to the loading lane. Because you can't cross the middle line in autonomous, you would have to wait for teleop to start. After a few games, I'm assuming other teams would be able to catch on and block you from ever getting into position. You would also have to avoid hitting the towers which are in the way.
Even if you were to build a robot that could launch the pieces, I still don't think it would be a game breaking strategy such as Las Guerrillas last year.
Unread 11-01-2011, 19:14
Erik Huang's Avatar
Erik Huang Erik Huang is offline
Jack of all Trades, Master of None
FRC #0296 (Northern Knights)
Rookie Year: 2010
Erik Huang is a jewel in the roughErik Huang is a jewel in the roughErik Huang is a jewel in the rough
Re: Feeder Bot
This was HUGE in our strategy meetings; we even found some really effective elim. strategies using this;
don't forget, to bring 6 tubes across the field in one game, you'd have to make the roundtrip in under 15s, without obstruction. most team will realize that, so they might be throwing into the field as well.
Here ye, here ye! Here cometh the robot!
Unread 11-01-2011, 21:42
Erik Huang's Avatar
Rookie Year: 2010
Re: Feeder Bot
out of curiosity, i was wondering the dimensions of the pin/peg on the scoring rack/alliance wall: i know it's make of, essentially, a cylinder with a flange on the end: what is the radius/diameter/circumference of the flange?
Unread 11-01-2011, 23:36
Chickenonastick's Avatar
Chickenonastick Chickenonastick is offline
Not a kebab
FRC #3256 (WarriorBorgs)
Rookie Year: 2010
Chickenonastick is on a distinguished road
Re: Feeder Bot
Sounds like a lot of work for the tube dispenser
Unread 12-01-2011, 00:31
Stephen of REX's Avatar
Stephen of REX Stephen of REX is offline
FRC #1727 (REX)
Stephen of REX is an unknown quantity at this point
Re: Feeder Bot
If I were to do this I would make the robot receive the tube out of the slot, rotate it 90 degrees, then catapult it over the field.
Go REX!!!
Unread 12-01-2011, 10:04
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Re: Feeder Bot
Do you think it would fly further in a vertical position?
Unread 26-01-2011, 16:07
pandamonium's Avatar
pandamonium pandamonium is offline
FRC #1836 (Milken Knights)
pandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond reputepandamonium has a reputation beyond repute
Re: Feeder Bot
I will have for you tonight video of team 73's prototype that Accurately shoots all sized tubes 10+ feet in the air and over 30 feet.
It was working yesterday but my camera was not
I am really excited because the feeder concept is slowly becoming a reality!
Unread 26-01-2011, 16:19
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Re: Feeder Bot
Hmm, I really want to see this. Sounds impressive. At this point in time, its a little late to change our pace, but this sounds very interesting...
Unread 26-01-2011, 16:26
MagiChau's Avatar
MagiChau MagiChau is offline
AKA: Michael Chau
FRC #0085 (B.O.B. (Built on Brains))
Rookie Year: 2010
MagiChau is just really niceMagiChau is just really niceMagiChau is just really niceMagiChau is just really nice
Re: Feeder Bot
I would applaud if you guys can manage to get your human feeder to just keep chucking tubes at it and your robot spits them out while on the edge of the lane safe from pesky robots.
Unread 26-01-2011, 16:58
Re: Feeder Bot
I think optimally we would not even need to move. Which would allow a more rapid fire, shooting tubes at about as fast as the human player can load them, approximately 2 - 4 seconds. For this to be viable we will need to add another 15 feet on to our range, but keep in mind this is a prototype made out of 4 pieces of wood and is not the most sturdiest of mechanisms.
Unread 26-01-2011, 19:43
jyh947's Avatar
jyh947 jyh947 is offline
FRC #3322 (Eagle Imperium)
Team Role: Leadership
Rookie Year: 2010
jyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to beholdjyh947 is a splendid one to behold
Re: Feeder Bot
If a human player were to throw a game piece, would hitting a tower cause your team to receive a red card?
Unread 26-01-2011, 19:51
rawrbot's Avatar
rawrbot rawrbot is offline
AKA: Nelly
FRC #1778 (Chill out!)
Team Role: Mascot
rawrbot is an unknown quantity at this point
Re: Feeder Bot
I am looking forward to seeing this feeder in action. i've been prototyping a tube launcher but wasn't able to get past 20 feet. a launcher feeder would be a huge advantage to any alliance.
  #15   Spotlight this post!
Unread 26-01-2011, 20:03
As Promised... Team 73 Teaser!
http://www.youtube.com/watch?v=jrgc6KNDgY8
Distance: Triangle 27 feet, circle 30 feet, Square 28 feet, also the side to side was Fairly accurate.
Height: we had to limit the height because we were in a room with a ceiling but it was still at least 12 feet
The design is using two single surgical tubes tied on either end.
Ideally I would like to get about 10 more feet out of a final design but I think that will come with a more rigid design
as always any thoughts or suggestions you have are welcomed
