Go to Post "its not working because you didnt program it right" *wheel falls off* "never mind" - Nin_estarSaerah [more]
Unread 11-01-2011, 01:23
Et Tu Brute Et Tu Brute is offline
AKA: Ray Pang
FRC #3473 (Team Sprocket)
Team Role: Electrical
Rookie Year: 2011
Et Tu Brute will become famous soon enough
Help with the cRIO Imaging Tool?
Hey guys,
Rookie Team Posting again . Our team is having problems getting the cRIO working. on the guide, we got stuck on Page 3 # 5
5) From the Select Image list, select the most recent FRC_2010_xx.zip file to download the FRC_2010_xx image to the cRIO. The FRC_2010_xx image consists support for LabVIEW, C/C++, and Java program.
http://usfirst.org/uploadedFiles/Rob..._Your_cRIO.pdf
Where are we suppose to find the "FRC_2010_(versionnumber).zip" files? Thanks guys, I appreciate the help.
Also, if it matters, we were planning on using Java. Thanks again!
Unread 11-01-2011, 08:58
tonystark_23's Avatar
tonystark_23 tonystark_23 is offline
FRC #2975
tonystark_23 is an unknown quantity at this point
Re: Help with the cRIO Imaging Tool?
If I am not mistaken, look in the "Getting Started with the 2011 FRC Control System.pdf". There will be a link to National Instruments that you can get the zip file. You will have to log in as a team of course.
EDIT: Sorry, the java does not have a link in the pdf file that I have. But the documents you are looking for are from the National Instruments website.
And are you kidding? We LOVE rookie teams
Unread 11-01-2011, 09:14
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
mwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond reputemwtidd has a reputation beyond repute
What language are you looking to get started in?
"Never let your schooling interfere with your education" -Mark Twain
Unread 11-01-2011, 09:15
FRC #2975
He stated Java.
Unread 11-01-2011, 09:25
mwtidd's Avatar
AKA: mike
Oops I've learned to ignore the last line in a CD post, unfortunately they had no sig .
If you get a dropBox account, I'll share my starting java code with you.
Also, I've posted a video walkthrough to getting started programming with your robot.
http://www.screencast.com/users/mtid...6-0d3410290fc0
The image should be available after you install the first plugin for netbeans.
the two links i got to in the video are:
http://joule.ni.com/nidu/cds/view/p/id/2261
http://dlc.sun.com.edgesuite.net/netbeans/7.0/beta/
and the netbeans update site is:
http://first.wpi.edu/FRC/java/netbea...te/updates.xml
Again where I do not image the cRIO in the vide, you should see the files you are looking for after you follow the steps through installing the netbeans plugin.
excuse the quality of the video, I made it in my basement late last night, but I think it should help. In order to get coding with my sample code, you'll have to get that dropbox account.
cheers
