Go to Post This is an open forum and it is a privilege to post here, if you don't agree with the rules then just don't post here. - dez250 [more]
Unread 11-01-2011, 17:17
3359prgsquad's Avatar
3359prgsquad 3359prgsquad is offline
FRC #3359
3359prgsquad is an unknown quantity at this point
LOST/STOLEN CLASSMATE
Our team lost our classmate laptop. Is there a website you can buy a new one or, can u use another laptop in compition????
Unread 11-01-2011, 17:24
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Re: LOST/STOLEN CLASSMATE
<R75>
Read the 'Blue Box' beneath the rule.
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
The FIRST "Where to get more" PDF:
http://usfirst.org/uploadedFiles/Rob...re_1-10-11.pdf
In the PDF, the classmate PC is listed as:
CTL Corp 2GO Classmate PC NBCE11F www.ctlcorp.com/go/first
Also, R75 permits you to use other computers, so long as the proper driver station software is loaded on them.
<R75> The Driver Station software provided on the FRC website (www.usfirst.org/frc/kitofparts) is the only tool permitted to collate driver/operator inputs and communicate them to the ROBOT. The Driver Station software must be revision 01.05.11.00 or newer.
Teams are permitted use a portable computing device of their choice (laptop computer, PDAs, etc.) to host the Driver Station software while participating in competition MATCHES.
Please note that 19V DC, 2A power will be provided at the PLAYER STATION for Classmates provided in the 2010 and 2011 KOPs via Classmate power adapters. The manufacturer has confimed that the power supply provided at the PLAYER STATION is compatible with both 2010 and 2011 Classmate versions. No 120VAC port will be available.
The FMS will verify that the Driver Station software is correct before it will permit a ROBOT to operate on the FIELD.
Unread 11-01-2011, 17:25
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
Not sure about where to get another Classmate, but you can use another PC.
<R75> The Driver Station software provided ......Teams are permitted use a portable computing device of their choice (laptop computer, PDAs, etc.) to host the Driver Station software while participating in competition MATCHES.Please note that 19V DC, 2A power....
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
Unread 24-01-2011, 08:59
cilginbilgin cilginbilgin is offline
FRC #2905
cilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the roughcilginbilgin is a jewel in the rough
Question Re: LOST/STOLEN CLASSMATE
We have lost our classmate , too but we have a major problem.We can't deploy our robotcode from another laptop so we think it's because we don't use the classmate.
And as all we know there are two accounts in the classmate.One of them is Developer and the other one is Driver Station.Do we have to make accounts like DS and Deployer in an another laptop too ?
Unread 24-01-2011, 09:21
JamesBrown JamesBrown is offline
Back after 4 years off
FRC #5279
JamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond reputeJamesBrown has a reputation beyond repute
You don't need to create two seperate accounts on the laptop. You can deploy code without the classmate, ensure your computer is set to the correct IP address (10.29.05.51 ) for your team.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 25-01-2011, 13:55
FRC #2905
I thought that we had to set our IP adress (10.29.05.6) for our team!
Unread 25-01-2011, 14:04
FRC #5279
I think you are right, either way running the drivers station software should set it correctly.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 25-01-2011, 14:48
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The DAP gets ...1, the cRIO is set to ...2, and the Driver Station has to be ...5 in order to work. Two years ago the Linksys was ...4 and I think any computer acting as a Dashboard had to be ...6, but this year there is no router and the Driver Station can either host the Dashboard or forward the data to any address you want. The programming computer is typically set to ...6, but that's not a requirement. It just has to have the right first three octets and a compatible subnet mask.
Unread 24-01-2011, 10:00
ttoollmmaann ttoollmmaann is offline
FRC #0870
ttoollmmaann is an unknown quantity at this point
Try a lego supplier. I saw these classmates at a tech conference this fall.
Unread 25-01-2011, 14:05
inkspell4's Avatar
inkspell4 inkspell4 is offline
FRC #3650 (Robo Raptors)
Rookie Year: 2011
inkspell4 will become famous soon enough
Everything you may need to buy is on the kit of parts website(as long as it is in the kit of parts.
the site specifies www.ctlcorp.com/go/first as the place to go to in order to purchace a new classmate but what vesion you had and the image drive may be needed in order to order a new one
check also to make sure this is nogt taken off of the 3400 dollars you are allowed to spend
it will set you back around 450 dollars but you can add extra features that other teams may not have like adding anouther gb of memory or updating the solid state drive.
good luck
Chesapeake Regional : 2013, 2012, 2011
Rookie Year: 2011
2013 RoboRaptors Team 3650 Programming Team Captain
Team Website : http://www.roboraptorsfrcteam3650.com/index.html
_____________________________________________
