Re: usage of denso window motor
Can you plese send me the cad for this photo
The CAD for those custom sprockets would also help our team a lot (we currently have no CAD skill).
Attached is a STEP file of the sprocket I machined in the photos above. All I did was download a regular sprocket model from McMaster-Carr (they have CAD models for most of their hardware (screws, nuts, shoulder bolts, sprockets, etc) on their website), use calipers to measure the metric output "spline" of the Denso motor, draw it on the part, and extrude cut it.
To machine it was a four step process. The first thing I had to do was machine a fixture plate out of 6061 aluminum. Then I machined about 90% of the sprocket features onto the 1/2" 7075 aluminum raw material. Then I took that part out, bolted it to the fixture plate upside down, and machined the sprocket teeth into it. The last step is to use a lathe or hand file to bevel the teeth. There is nothing in this CAD model to keep the sprocket on the shaft of the motor or to support it for cantilevered loads. In the second photo I previously posted, our solution was to machine a custom bushing out of Delrin to both support the shaft and to keep the sprocket laterally in place on the shaft. |
My team 1946 thank you for your help
opps - there it is, thanks!
Hey Arthur, Nice work! Do you have any kind of CAD file you could share?
Is These chain #25 Or #35 series
the next quation do you have base technical diagram |
It's for #35 chain, and the diagram is already attached on my previous post.
Yes, I meant the sheet metal
#10
We used this motor this weekend at the peachtree regional and had no success with it. Needless to say we didn't use a sprock. One of our sponors is willing to machine the sprocket for this part if we had it in a CAD file. Can you share the file you have with use so that we may have this part made for our next regional in Knoxville?
#11
#12
#13
Would you happen to have a picture of your set up? |
#14
How much are we allowed to modify the window motors/gearbox? Can we use the gearbox for another motor?
#15
reference rule <R47>
