Go to Post This is the hint that never ends, yes it goes on and on my friend. Some people start guessing not knowing what it was, and they'll continue to guess forever just because... - JaneYoung [more]
Unread 11-01-2011, 23:57
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Rookie Year: 2007
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Minibot Rules-Support
It’s definitely not a popular view, but I support the new minibot rules for engineering and inspiration reasons. Regarding the Tetrix/FRC debate, I have no comment and would prefer this thread be used to discuss the engineering merits (or lack thereof) of the new rules.
Note: If you haven’t read team update 1 now would be a good time to do so.
Here are some counter points to arguments I’ve seen against the new ruling.
1. “The new rules make the game boring” or “Slower is boring”
Fast does not equal exciting. Launched or self-launched minibots from experienced teams could easily reach the top of the tower in <.5 seconds. This is less time than it takes to scan the field. Audience members wouldn’t be able to see a race; they’d see four different lights go on almost instantaneously.
Now the end game might go more like this: 1726’s minibot out of the gate first, but moving slowly. 1114 got a late start, but is moving more quickly, wait it looks like they’re having a traction problem and are slipping back down the pole, 1726 wins! <-- This is exciting.
2. “The new rules discourage diversity”
I don’t see the universal minibot design people seem to think the team update requires. Allowing launched minibots would force every competitive team to design a projectile. This new rule makes a variety of different climbing mechanisms feasible. Off the top of my head I see several different robot designs: two ratcheting jumars joined with a linkage, a multi wheel design which clamps onto the pole, or a single magnetic wheel.
The design challenge can now be stated: “Design the lightest possible device which converts rotation motion from the motors at max efficiency into vertical motion.” There are literally hundreds of ways to do this.
3. “All robots will now finish at roughly the same time”
It’s difficult to design a minibot which optimizes weight and hits the Tetrix motors peak efficiency. Only teams with a very solid grasp of engineering fundamentals will be able to do so. Many minibots will move at a non-optimal speeds or slip. I predict minibots will finish within seconds of each other as opposed to milliseconds for launched minibots.
I strongly support the GDC’s decision and look forward to seeing the wide variety of minibots produced by clever teams.
Unread 12-01-2011, 00:00
Jared Russell's Avatar
Jared Russell Jared Russell is offline
Taking a year (mostly) off
FRC #0254 (The Cheesy Poofs), FRC #0341 (Miss Daisy)
Jared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond reputeJared Russell has a reputation beyond repute
Re: Minibot Rules-Support
We'll see how wide the variety of minibots is once a week of regionals has come and gone and whatever design ends up performing best is duplicated by dozens to hundreds of savvy teams.
Unread 12-01-2011, 00:10
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
1. Given the choice, would you watch a horse race, or a tortoise race? Sure, there might be interesting tortoise racing dynamics, but the horse race has the same thrills at a much faster pace -- which is why it is more exciting.
2. The only way that will be remotely competitive (or even score at all I imagine) will be two wheels geared at the ratio for optimum power, attached to the tower with enough grip to climb, but not so much as to make the powertrain inefficient. You don't have time to ratchet up the tower, 10 seconds is pretty quick! And if they weren't easy to copy... why did the GDC shroud theirs in plywood for the kickoff video?
3. I agree with you here. Each match will end will end with lots of minibots either still climbing, sitting at the base trying to climb, or scattered all over the field because they weren't held securely enough.
I agree it remains an interesting, difficult challenge. Lots of teams will leave it until last minute, and lots of teams will field robots with systems that ultimately don't work, just like many ramps we saw in 2007.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 12-01-2011, 00:41
Rookie Year: 2007
Given the choice would you watch a horse race or a bullet race? Horse races (and turtle races) are interesting because you can see the competition. Races between bullets (or launched minibots), come down to trusting the electronic scoring mechanisms to tell you what happened in a race too fast to watch.
I don't think this will happen. There have been lots of opportunities for savvy teams to copy a winning design in the past, and it hasn't happened often. Also, it is deceptively difficult to copy a good design without fully understanding it. The best minibots will have lots of custom parts including ultra-light weight custom gears and will be difficult to copy.
Plus if everyone copies a week one design, an innovative week two team will steal the show with a better design.
Unread 12-01-2011, 00:54
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
And if [MINIBOTS] weren't easy to copy... why did the GDC shroud theirs in plywood for the kickoff video?
They shrouded their HOSTBOT in the same black stuff - and I'd be willing to bet it was just a kitbot inside.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 12-01-2011, 01:32
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
Rookie Year: 2007
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Aesthetics, most likely. Like Steven said, the kitbots (and Woodie did say they were kitbots) were covered with the same black cardboard, and if I recall correctly, it was that way in previous years, too.
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
I do suppose that in several ways, the MINIBOT race has now become more challenging. And I do agree with the fact that the teams with the solid grasp on physics and engineering principals will succeed in making it to the top first. New constraints bring new challenges. The difference between the top tier and bottom team teams is lessened, which means the top tier teams really need to perfect their game.
