Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 12-01-2011, 15:43
Bryscus's Avatar
Bryscus Bryscus is offline
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Bryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud ofBryscus has much to be proud of
4W Maximum Power Servos? Huh?
Guys,
I've been an RC enthusiast for probably 10 years now and I've never (I MAY have seen a power curve, I can't remember) come across a power rating for a servo. I've been on the phone with the Hitec and JR tech support and they have no idea how FIRST has come up with such a number and I have no idea on how I would prove that a different servo meets the 4W Maximum requirement.
In the Rules:
<R45> Motors specifically permitted on 2011 FRC ROBOTS include:
B. an unlimited number of COTS servos with a maximum power rating of 4W ,
- The burden of proof that the servo meets the criteria is on the team. The team must show the appropriate data sheet to the inspector.
Any thoughts or insights? We would like to find some more powerful servos for gear shifting, but I've come do a dead end. We would prefer to try to find an electrical solution instead of a pneumatic one. Thanks.
- Bryce
The opulence of the front office decor varies inversely with the fundamental solvency of the firm.
Unread 12-01-2011, 15:51
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Re: 4W Maximum Power Servos? Huh?
James Prescott Joule would argue that a reasonable estimate could be calculated based on other commonly available specifications.
Unread 12-01-2011, 16:13
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
As his friend James Watt would have helped by saying it's 0.00536 horsepower.
All of the servo people give you rotation speed and force output, so you convert and go.
Take a screenprint of the servo specs.
For what (not watt) it's worth, those are pretty small servos.
Foster - VEX Delaware - 17 teams -- Chief Roboteer STEMRobotics.org
2010 - Mentor of the Year - VEX Clean Sweep World Championship
2006-2016, a decade of doing VEX, time really flies while having fun
Downingtown Area Robotics Web site and VEXMen Team Site come see what we can do for you.
Unread 12-01-2011, 16:19
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
Doesn't one need an efficiency rating as well? I don't think they mean power in terms of mechanical power, but rather in terms of electrical load on the digital side car.
- Bryce
Unread 12-01-2011, 16:25
Motor ratings are done as power output, not power consumed. So you don't need the efficiency. Had they cared about the power input they should have said "draws max of 0.33 amps at 12 volts".
But since you brought it up, drag the question over to the Q&A site and ask, power in or power out and see what watt they want.
Unread 12-01-2011, 16:34
Bryscus's Avatar
EE, CpE
AKA: Bryce B.
FRC #0180 (SPAM)
Rookie Year: 1999
I agree with you on the power output bit. I don't know why they would care about limiting the output power, but I'll post the question and see what I get.
- Bryce
Unread 12-01-2011, 16:49
EricVanWyk EricVanWyk is offline
Rookie Year: 2000
EricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond reputeEricVanWyk has a reputation beyond repute
Send a message via AIM to EricVanWyk
Man, this is harder than I thought - these servo vendors sure don't like to make things easy for us. What the heck is an ounce inch? seconds per 60 degrees? Seriously? I miss newton meters and radians per second
I poked a bit at some of the servos that have been legal in the past to see if my calculation method was ballpark valid. First I converted to Nm and rad/s and then multiplied to get Nm/s (W). I used whatever the companies advertised for 6V.
HS-475HB:
76.0 oz-in Stall
0.18 sec/60° No load
.536 Nm, 5.81 rad/sec, 3.12 W
HS-332HD/HS-325HB
51.0 oz-in Stall
0.15 sec/60° No load
.360 Nm, 6.98 rad/sec, 2.51 W
From this, it looks like no load * max torque might be the formula they use. Wouldn't hurt to officially ask.
Also, can someone please please please check my math? Its quite possible that I dropped something during unit conversion.
Unread 12-01-2011, 16:52
Rookie Year: 2000
Eh, each sidecar can push 18 Watts total to the servos, and only takes out the servos if it is over loaded. I think it is mechanical power.
Unread 12-01-2011, 17:55
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Your math is correct for stall torque * no-load speed. Which, of course, isn't the same as max power, which is (stall torque * no-load speed)/4. My post above uses the latter convention. I take it you were looking for whatever formula the GDC might have been using when they developed the 4W limit. I think it's definitely worth the Q&A to see what they were thinking of when they wrote this one.
Unread 16-01-2011, 20:33
hilo90mhz hilo90mhz is offline
FRC #2024
hilo90mhz is an unknown quantity at this point
Does this mean we can use VEX servos/drive motors in the main robot?
Would be helpful for our claw actuator.
Unread 16-01-2011, 20:36
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Servos, yes, provided that they are under 4W. VEX motors, not so much, due to <R46> disallowing anything not allowed under <R45> and <R45> not specifically allowing VEX motors.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 12-01-2011, 19:29
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
I too wish that torque ratings were standardized. I've been on websites that have a different unit for every product they sell. However, newton meters are HUGE units. Servos, in general, are really weak. Milli Newton Meters are used more more often in this case (or kg-cm, or oz-in, or g-cm, or...)
Unread 12-01-2011, 20:17
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
I sure hope they aren't using kg-cm or g-cm for torque measurements. (Kilo)grams are a unit of mass, not force.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 12-01-2011, 21:18
Rookie Year: 2000
Check out the kg-cm on this sheet:
http://www.servocity.com/html/hs-325hb_bb_deluxe.html
I wonder if their performance depends on local gravity...
  #15   Spotlight this post!
Unread 13-01-2011, 13:29
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Wouldn't the electrical power draw (max) be stall current times the operating voltage? And by stall, I mean not just current drawn when holding position but just barely holding position against the maximum torque load.
- Steve
