Go to Post If time only weren't a factor, everything would be done. - Schnabel [more]
Unread 12-01-2011, 16:56
CuyValDar CuyValDar is offline
None #3717
CuyValDar is an unknown quantity at this point
Power Distribution Module Wiring
How does one push wires into the power distribution module?
Unread 12-01-2011, 17:02
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
Re: Power Distribution Module Wiring
In the kit of parts website http://usfirst.org/frc/kitofparts look at the Power Distribution Board data sheet.
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Cuy,
The WAGO site has a tutorial on how to use these. It requires a WAGO tool or a small screw driver. The took is inserted in the upper part of the terminal and pushed into place or manipulated to open the contact. While you hold it open, you insert the stripped wire (5/8") and then while holding the wire in place, remove the tool. It takes some practice so don't be discouraged.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 12-01-2011, 17:28
None #3717
Thanks for the assistance. This is our first time competing for five years.
Unread 12-01-2011, 17:50
DonRotolo's Avatar
Back to humble
FRC #0832
Look at Page 21 of this presentation (the first page after "Helpful Hints"), it will show you how to do it right and avoid breaking things:
http://www.oregonfirst.org/wp/wp-upl...onics_2009.pdf
