Go to Post You know when the school health nurse advises "always wear a condom"? She doesn't actually mean "ALWAYS". ::safety:: I think Dean and Woodie have a pretty good idea of when they need safety glasses and when they don't. Jason - dtengineering [more]
Unread 12-01-2011, 18:17
Kohala2460's Avatar
Kohala2460 Kohala2460 is offline
AKA: Michael
FRC #2460 (Na Paniolo)
Kohala2460 is an unknown quantity at this point
First Touch I/O Module
We have an idea to use analog outputs from 3 different sources for the drivers station, however we do not know how to program the First Touch I/O Module. Some basic code, or where to get some would be very much appreciated.
-Team 2460
Unread 12-01-2011, 18:19
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
FRC #0973 (Greybots)
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Re: First Touch I/O Module
How To Configure Your I/O Module
Source Code - WPI
That should get you started. I am not in the programming section of the robot but I believe that most of the info can be used from these. Check the pages on here as well. They should provide you with some answers.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 13-01-2011, 02:12
The most direct way to do this is to configure the I/O board as normal, then simply read the analogs you want on the robot. You don't mention a language, but all have access to the FT values via the DriverStation object or library.
On the robot, do the math to combine them into the appropriate control values e.g. speed= (x+y+z)/3, or whatever you need.
Greg McKaskle
