Go to Post Driving without the trailer was quite fun, but driving with the trailer was just painful. - Paul Copioli [more]
Unread 12-01-2011, 19:02
Weisemanjohn Weisemanjohn is offline
FRC #3335 (Cypress Ranch Robotics Team EMP)
Team Role: Leadership
Rookie Year: 2010
Weisemanjohn is an unknown quantity at this point
gearbox compatibility issues
I'm working on trying to come up with ways to hang the tubes on the scoring grid. I'm thinking of hooking a 24" stroke pneumatic linear actuator to a set of 2 gearboxes. I want to attach the banebot rs 550 to a p60 gearbox and then into an andymark toughbox mini to lift the arm. The problem is the output shaft for the p60 is larger than the shaft of a 2.5"CIM that the toughbox is meant for. Does anyone know where I can get an alternate output shaft for the p60 or alternate input gear to the CIM gear provided? I have already checked AndyMark and McMaster for gears.
Unread 12-01-2011, 19:17
DonRotolo's Avatar
Back to humble
FRC #0832
Re: gearbox compatibility issues
Are you saying that the diameter of the shaft of (something) it too large to do what you want? If so, find someone with a lathe and have them make the too-large shaft smaller. Or, if possible, use a drill to make the hole into which the shaft needs to go larger.
Unread 14-01-2011, 14:54
Rookie Year: 2010
Either way I will need to remake the keyhole on the gear to match the one on the output shaft of the p60 gearbox. is there any way to do that simply?
Unread 14-01-2011, 14:58
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Don (or anyone else),
Have you done this before (i.e. turned down the BB output shaft to the diameter of the CIM pinion bore, and then milled the keyway in)? I was discussing a BaneBots to Toughbox last night, and wasn't sure what teams have done before. I imagine turning down the hardened shaft would be a royal pain.
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 14-01-2011, 15:14
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
I would wait on the 24" cylinder until we get an update on how many air tanks we are allowed for storage or if we can use a non-bimba cylinder. If we only get the one tank in the kit that cylinder will be almost unusable.
I would suggest two 1 1/16 or 1 1/2 cylinders put together Darth Maul style if we are limited.
Unread 14-01-2011, 15:19
Rookie Year: 2010
In the FIRST Choice, they gave the option to get another tank, that would make you think you would be allowed more than what was provided in the KoP
Unread 14-01-2011, 18:58
JB987 JB987 is offline
AKA: Joe Barry
FRC #0987 (HIGH ROLLERS)
Team Role: Coach
JB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond reputeJB987 has a reputation beyond repute
Wait is over...see Update #2. Good news for all!
Unread 14-01-2011, 19:15
Teched3 Teched3 is offline
Hodge1
FRC #0175 (BuzzRobotics)
Rookie Year: 1996
Teched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud ofTeched3 has much to be proud of
Smile Re: gearbox compatibility issues
As far as I know, the banebots output shaft is not hardened, and you should have no trouble reducing the diameter. You would need to deepen the keyway on a vertical mill (2 mm) . The shaft diameter is 8mm on the CIM (.315) motor. To be certain the shaft is not hardened, file test it. If it files, it can be cut easily with HSS or carbide lathe bits.
Sweat the details
Why is there never enough time to do it right, but always enough time to do it again!
Even if you're on the right track, if you sit still, you'll get run over!!!
Unread 14-01-2011, 20:06
Rookie Year: 2010
how can we widen the keyhole in the CIM gear to match the BB shaft?
Unread 14-01-2011, 20:24
Best Available Data
You won't need to. When you turn down the BaneBots output shaft from .5" diameter to .315" diameter, you'll turn off the keyway (i.e. the material the keyway is in will be taken off). You'll then need to mill a new keyway into the BaneBots output shaft that matches the CIM pinion keyway.
See this drawing.
BaneBots says the output shaft is hardened 4140. Is this not the case?
Unread 14-01-2011, 20:51
Rookie Year: 2010
how could i mill the keyhole on the bb shaft, either piece we lathe/drill we will need to remake the keyhole.
Unread 14-01-2011, 21:36
Hodge1
Rookie Year: 1996
You will need to broach the gear with a 2mm A broach using an arbor press, and use a vertical mill with a 2mm end mill to mill the keyway into the shaft. Alternately, you use a 3/32 A broach and 3/32 mill, but have spare parts made for insurance. I usually mill the keyway a little deeper than 2mm to account for the chordal distance across the shaft. In addition, when you order keyway stock, get unplated steel stock as plated stock is a little tight and will require some sanding or filing for a proper fit.
Sweat the details
Unread 15-01-2011, 00:30
DonRotolo's Avatar
Back to humble
FRC #0832
No, we have not. I misunderstood the question apparently.
In a case where I had a motor with an xx size shaft and
A) Something that can be drilled out: Drill it out. (e.g., a gear that's not hardened)
B) Something else (Like a CIM gear that's hardened): Make a shaft adapter: One end drilled for the motor, the other end sized to fit the (something else).
It would be a royal pain to cut down the shaft of a motor while it is still part of the motor, and I would be reluctant to attempt it. If space for a shaft adapter was an issue, I'd seek a different gear.
Or did I misunderstand the question again?
