Go to Post I am all for high school sports, but as Dean continually preaches, we sometimes are not putting enough emphases in the right places. - Bill Beatty [more]
Unread 13-01-2011, 09:49
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Help for a rookie team?
The Robot Code light will only come on when code is running. A slightly annoying fact (for rookies at least) is that the current control system has no "default code", meaning that when you image the cRio there is just nothing. In LabVIEW, you would go to Builds, then right-click "FRC Boot-Up Deployment" and set "Run As Startup". Then, code will exist on the cRio. If you want to test your code, you can go to Robot Main.vi and press the "play" button, and it will download your code temporarily (you loose it when you power down), but it is faster and you can see the front panels, which is useful when debugging.
Also - I have honestly never used the DB9 serial connection. Most things (in LabVIEW at least) can be solved with the indicator lights on the cRio itself (and its surrounding boards such as the DSC), the Driver Station, and LabVIEW.
You don't have to use the Classmate to download code. Any laptop which LabVIEW will run on (anything running Windows, no macs) will work. You would use it exactly the same, just set a static IP address on the same subnet (but not one of the reserved IP addresses).
If you have any questions about LabVIEW, feel free to PM me.
Oh yeah - the robot code light isn't the fastest light either. It shouldn't take more than a minute, though.
Kettering Motorsports
Unread 12-01-2011, 21:44
Karibou Karibou is offline
Steel is love. Steel is life.
AKA: Kara Bakowski
FRC #0341 (Miss Daisy)
Karibou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond reputeKaribou has a reputation beyond repute
Send a message via AIM to Karibou
Originally Posted by cjackson View Post
I don't mean to sound whiny, but we really don't have much support or knowledge of what to do.
Welcome to ChiefDelphi!
You don't sound whiny Answering your legitimate questions is what we're here for, and as far as I can tell, your questions are legitimate. I don't have enough knowledge to answer them, but someone else in the the CD community can. You did a great job of stating your questions clearly and directly, which is going to get you more specific help. Good job!
Kara Bakowski
Michigan Technological University///Materials Science and Engineering '15///Go Huskies! #tenacity
kabakowski(at)gmail(dot)com
FRC 341 (2016-present): Mechanical/build mentor
Volunteer (2010-present): MAR Seneca '17, FTC Hat Tricks Qualifier '16, Brunswick Eruption '16, MAR Montgomery '16, MAR Westtown '16 Portcullis Victim, MAR Springside-Chestnut Hill '16, Ramp Riot '15 '16, FiM Escanaba District '14 '15, MidKnight Mayhem '13 '15 '16, FiM Detroit District '13, IRI '10 '12, FiM Waterford District '11 '12, MARC '12, CMP Galileo '11
FRC 1189 (2008-2011): Team Captain, Pit Crew, Website group leader, Team Education group leader, Proud Alum. We've got spirit, yes we do...
WMWBS '10 '11
