Go to Post 118 embodies everything this entire program is supposed to be about: INSPIRATION. Respect that. Acknowledge that. Support that. - barn34 [more]
Unread 12-01-2011, 21:25
Alyssa Reiman Alyssa Reiman is offline
FRC #1111
Alyssa Reiman is an unknown quantity at this point
Tank drive
My team just swapped to labview this year and we are experiencing some difficulties relating to it. One of these difficulties is changing arcade drive to tank drive. We followed some tutorials:
http://www.chiefdelphi.com/forums/sh...90&postcount=5
and a few others similar to it, but none of them have worked for us. It just stays as arcade drive.
If you could help us do this, it would be greatly appreciated.
Unread 12-01-2011, 22:13
Dustin Shadbolt's Avatar
Dustin Shadbolt Dustin Shadbolt is offline
In a server room somewhere...
AKA: Dustin Shadbolt
FRC #1555 (Team PULSE)
Rookie Year: 2010
Dustin Shadbolt is on a distinguished road
Re: Tank drive
Hey,
You would change the drive by right clicking the Arcade Drive VI and going to replace> Robot Drive Palette>Tank Drive. And Save. If that don't work then I would suggest just placing the Tank Drive VI after deleting the Arcade Drive VI. It's under the WPI>Robot Drive>Tank Drive VI. Then wire your joystick inputs. If you need more help, feel free to ask for it!
Unread 14-01-2011, 15:54
jackforey jackforey is offline
FRC #3717
jackforey is an unknown quantity at this point
Re: Tank drive
but where can I get the tank drive file for lab view?
Unread 14-01-2011, 17:34
Mark McLeod's Avatar
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Tank drive
Install the LabVIEW Update to get all the 2011 vi's and framework.
Software Updates
Unread 18-01-2011, 23:05
Jimmy the Kidd's Avatar
Jimmy the Kidd Jimmy the Kidd is offline
Programmer, Scouter, Tactician, etc
FRC #0364 (Team Fusion)
Team Role: Tactician
Rookie Year: 2010
Jimmy the Kidd is an unknown quantity at this point
Re: Tank drive
Be careful though. If you just strictly change the module, it might not be set up right. Make sure to check your joysticks and pwms before you deploy the code.
