Go to Post It would appear that your PLTW teacher succeeded in tricking you into learning something after all. Teachers are sneaky that way! - Richard Wallace [more]
Unread 12-01-2011, 22:01
TheGreatPhil TheGreatPhil is offline
FRC #2264
TheGreatPhil is an unknown quantity at this point
Forklift Rack and Pinion
Hi, my team is looking at a forklift design to raise the inner-tubes from the ground to the highest shelf. What kind of thoughts do you have about an aluminum pole with a rack on the back, and a Fisher Price motor connected to a gear traveling up, with that assembly connected to a forklift inserted into the opposite side of a pole and movable up/down. Sorry if this is a little complicated to understand, I'll try and crudely ASCII it: =|}xO, where = is the forklift, | the pole, } the rack, x the gear, and O the motor. Thanks!
Unread 12-01-2011, 22:09
Justin Stiltner's Avatar
Justin Stiltner Justin Stiltner is offline
The big guy
Rookie Year: 2000
Justin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud ofJustin Stiltner has much to be proud of
Send a message via ICQ to Justin Stiltner Send a message via AIM to Justin Stiltner Send a message via MSN to Justin Stiltner Send a message via Yahoo to Justin Stiltner
Re: Forklift Rack and Pinion
Will it work, sure anything is possible. But realize that you will only have the length of your rack of extension. Is that enough to reach the pegs you are going for? Can you source a rack long enough to do what you want to do, and still not weigh a ton, and attach the pinion to the FP gearbox?
look around on www.howstuffworks.com and the like for examples of how a forklift, crane, elevator, etc. work this may give you more ideas, or help to refine your own.
Justin Stiltner
Lead Robot Inspector, VCU Regional
Unmanned Systems Lab, Virginia Tech
KI4URQ
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #5811 (The BONDS)(EWCP)
Rookie Year: 2010
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
If my understanding of what you are saying is correct, then my team used this design back in 2005 when lifting tetras for the game Triple Play. It's definitely doable.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
Unread 12-01-2011, 22:15
FRC #2264
What kind of speed were you looking at for a bottom > top travel?
Unread 12-01-2011, 22:14
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
So I think that a fork lift can take its ideas from an elevator:
Its just a motor that just pulls the the chain up and down. Here is a rough sketch:
http://img713.imageshack.us/img713/923/liftm.jpg
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 12-01-2011, 22:21
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Heh! 1276 built exactly this robot in 2007. Take a look, and I can answer any questions.
Pictures!
Closeup of the carriage
Match Videos!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 12-01-2011, 22:25
FRC #2264
Pictures!
Match Videos!
Hey, thanks for replying. What kind of speed were you looking at for complete up/down travel, and what kind of difficulties did you have with the engineering?
Unread 12-01-2011, 22:33
Best Available Data
Pretty broad question Batman!
Don't remember honestly. It was fairly quick... but not dangerously so. You could probably calculate it from watching the match videos. A 3 second traverse of the tower perhaps? (so about 2 feet/second).
We had a lot of fabrication difficulties. If I were to do it again, especially without access to such a great aluminum welder, I'd do it with a square tube mast. If you used a cut up belt, you would save yourself a lot of machining time (especially if you don't have your own equipment). The hinge is important. Ours was not strong enough, so we ended up just pinning the tower at 6 feet tall. If we had planned to make the hinge strong from the beginning, we could have left it actuated. We had to use a junky piano hinge from the hardware store McMaster sells much more substantial ones. There are big shock loads as it comes upright.
As you can see from the last picture in the gallery, you can literally do this with a cut up belt, pulley, and 2x4.
Unread 12-01-2011, 22:50
scottydoh scottydoh is offline
CAD, Mechanical, Alumni, Mentor
AKA: Scott
FRC #0810 (Mechanical Bulls)
scottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to allscottydoh is a name known to all
Send a message via AIM to scottydoh Send a message via Yahoo to scottydoh
What about a lead screw?
www.smithtownrobotics.com
Robot Inspector (SBPLI 2011)
2011 Johnson & Johnson Gracious Professionalism (NYC) Judges Award (SBPLI)
2009 Xerox Creativity (SBPLI)
Mechanical Bulls; Student Leader 2006-2008, Mentor 2009-Present
New York Institute of Technology - Architecture '13 | Design Portfolio:www.coroflot.com/sdifiore
