Go to Post (pfft, kid... I sound like I'm Baker's age) - Amanda Morrison [more]
Unread 12-01-2011, 22:09
Schmidty850's Avatar
Schmidty850 Schmidty850 is offline
Team Captain
AKA: Daniel
FRC #1999 (Outer Limit)
Team Role: Student
Rookie Year: 2010
Schmidty850 is an unknown quantity at this point
Exclamation Scoring Pegs
Hey guys I have a minor question for yall. Either I didn't see it in the manual or it just isn't there, does anyone know the height of the scoring pegs from the floor. We are designing our robot and we just want to be able to drive up to the peg of our choice and slip the tube on, no lifts to make it easy. But we need to know the height.
Thanks
Daniel
Unread 12-01-2011, 22:34
SteveGPage's Avatar
SteveGPage SteveGPage is offline
Mentor - Scouting and Strategy
AKA: Steve
FRC #0836 (RoboBees)
SteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond reputeSteveGPage has a reputation beyond repute
Re: Scoring Pegs
Thanks
Daniel
Chief Delphi has a great search function for previously posted threads. This specific question comes up several times a day!
Here is a link to one such post.
http://www.chiefdelphi.com/forums/sh...t=Scoring+pegs
Hope this helps!
Steve
FRC 836, The RoboBees www.robobees.org
growingSTEMS www.growingSTEMS.org
2017: Southwest VA, Northern MD, Chesapeake District Championships, Championships
Unread 12-01-2011, 22:46
Team Captain
AKA: Daniel
Team Role: Student
Rookie Year: 2010
Re: Scoring Pegs
Thank you so much, to be honest I totally forgot about even searching it. Thank you
Unread 13-01-2011, 02:35
Navid Shafa Navid Shafa is offline
FIRST Hiatus/Retired?
Rookie Year: 2007
Navid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond reputeNavid Shafa has a reputation beyond repute
Re: Scoring Pegs
Outer posts: 30 inches, 67 inches, 104 inches
Middle post: 38 inches, 75 inches, 112 inches
Ranging from 2.5ft to 9-1/3ft, That's going to be a fun challenge!
2015 & 2016 Fantasy FIRST Champions [Rotten Fruit Alliance]
Elgin Clock Award Winners: '13, '15, '16
Team 1983 | Alumnus, Former Mentor| Team_ 360 | Former Coach | Team 5803 | Former Mentor
"Once a Skunk, Always a Skunk"
Founding Member
Unread 13-01-2011, 10:52
Retired Starman Retired Starman is offline
FRC #3573 (Ohms)
Retired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud ofRetired Starman has much to be proud of
Re: Scoring Pegs
To determine once and for all what the peg heights are, go to this link:
http://www.usfirst.org/roboticsprogr....aspx?id=18763
Download the Game Specific drawings for all the playing elements on this year's field. Specifically, look at drawings GE-11000 through GE-11005. From these you can determine measurements from the 11 gauge steel base plate that sits on the floor up to the bottom of the pegs, or to the center of the end disks which are welded tangent to the bottom of each peg's pipe, or to the top of this disc. Since I don't know how you will plan on aiming at the pegs, I won't publish actual dimensions here, but you can easily calculate them.
Plans are also on this site for team-built pipes made from PVC plastic pipe. Be careful when you make the pipes out of plastic. Not all tee-fittings are the same size, and pipe doesn't always bottom out when glued into the tee-fittings, so be sure to measure the finished products when you make them.
Unread 13-01-2011, 22:16
Bill_B Bill_B is offline
You cannot not make a difference
FRC #2170
Bill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond reputeBill_B has a reputation beyond repute
Re: Scoring Pegs
You should assemble, then measure your rack pipes before taking them apart for application of glue and reassembly into their final configuration. Also be sure to have a plan for keeping the pegs all going in the same plane. Marks on the fitting Tees and pvc tubes will help with alignment. Keep a sharpie marker handy.
Nature's Fury FLL team 830 - F L eLements
FRC team 2170 - Titanium Tomahawks
Unread 14-02-2011, 20:36
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: Scoring Pegs
Hey - Retired Starman - I am not afraid of mechanical drawings; but figuring out the peg heights from the drawing FIRST supplied is a giant pain the anatomy; and among all the things I might encourage students or myself to practice, that sort of tedium isn't high on the list. Instead I would urge folks who create drawings to practice making their products as useful as possible.
With that in mind, if you have gone through the detective work / chore of doing the arithmetic, and of factoring in all of the additions created by the baseplates and boxes the poles rest in, how about sharing the result with us?
Listing a summary of the various parts' contributions would set a useful answer apart from the ones that simply list 6 numbers.
Blake
PS: I'm not above suggesting that lazy folks should read the rules and other docs instead of asking the rest of the world to do their homework for them; but I think this falls into a different category.
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
