| Thread Tools |
Rating:
Display Modes |
DAP-1522 - Errors Setting IP Address
We're having trouble configuring the Static IP address setting on our new DAP-1522 radio. We followed the instructions in the manual "How to Configure Your Radio.pdf", and tried to enter an access point IP address of 10.1.0.1 (to comply with the form 10.xx.xx.1 for team # 100).
An error message pops up that states that 10.01.00.1 is an INVALID IP address. We tried entering the IP address in a variety of forms thinking it may be a parsing error (10.1.0.1, 10.01.0.01, 10.01.00.01, etc.). All resulted in the same error message. The radio WILL accept 10.19.95.1 (as in the example) and 10.10.0.1 (tried in desperation) but will not accept the proper IP address required for Team 100. What else should we try? |
Re: DAP-1522 - Errors Setting IP Address
We had the same problem with 10.21.06.1
We finally fixed the problem by using 10.21.6.1 I don't know how this works if you have a team 216, but it's what we will use for now. As for team 100, I don't know. It seems to dislike leading zeros though. Perhaps something that should be brought up with FIRST? |
I'm well aware of this, but it is what we are using for now until we can figure out how to get it to accept 10.21.06.1
Oh your right, my bad, I had misread what myself and the others wrote. XD My mistake
For the OP have you tried 10.1..1? Seeing as it doesn't like 0's it might accept nothing there.
I tested your IP address with our radio and didn't get the error message, not that it helps you fix your issue.
I did confirm that it doesn't like, and won't accept, leading zero's. e.g., Good: 10.3.58.1 Bad: 10.03.58.1 Last edited by Mark McLeod : 14-01-2011 at 14:12. |
