Re: Manipulators: Claws vs rollers?
The same concept applies to all the other parts of your robot, too. "Testing" is indeed part of the design process. |
Ive found that in essentially every game but 05 rollers are best for picking up an object. With rollers you can have a very active control on the object and pick up the object wthout stopping.
With any design remember how high you have to go to reach the highest row. The less mass the better.
what would you use for a roller or collector that is legal in FRC? i know vex wheels are not legal. And im looking for a collector that is smaller that 4in in diameter? What would work
We did pretty good in 2007 so we're gonna try to stick with our claw design as much as possible from that year with some inspiration from our even more successful 2008 bot for the elevator.
Thanks, Sunny |
Those are slide rails that are designed for use in a copier drawer were used for the elevator. Just be warned when using them that they can give out (check out 7:52 into the video. Ironically we won the Quality Award after this happened). |
- Sunny |
#10
We looked at a claw and a gripper, and made quick ptototypes of each. We are going forward with a claw, but not everyone has full confidence at this point.
A claw is a lot simpler and the parts that are exposed to damage (extended) are easier to fix or replace. It is lighter. A claw can't rotate a tube after picking it up, but this year most or all tubes will essentially be horizontal on the floor. We can do any necessary rotation with the arm. A claw can be made to pick up a tube that is in contact with the robot - and robot/tube contact should orient and locate the tube for pickup. A claw requires fewer wires running out to the tip of the maniplator. It is easier to modify the details of a claw (grip materials, length of the fingers, amount of clamping, etc. Hopefully, our claw will be done soon enough to build a roller claw if it doesn't work! I expect the tubes to be inflated quite tight. Inflation pressure really changes the dynamics of the pickup. Whatever you use, be sure it can be adjusted for, or is relatively unaffected by tube pressure. Finish early - then practice, break it, improve it, repeat. |
#11
No such thing as finishing early! |
#12
What are peoples thoughts on how fast they think the roller should run to adequitly pick up the tube?
#13
No, really. Depending on the material surface, diameter, and geometry of your roller claw, that answer is going to have a lot of play. Design, prototype, test, critique, redesign, re-prototype, test, critique, redesign, re-prototype, test, cry a little, critique... Repeat these steps as necessary! |
#14
sweet idea REX cant wait to see your crazy design this year
