Go to Post "Things don't get done unless somebody does them." - CaptainKirby [more]
Unread 13-01-2011, 15:43
grosh grosh is offline
FRC #2147
grosh is an unknown quantity at this point
VEX motor w/o robot controller?
Can a VEX motor (PWM-3wire) be modified to work directly connected to a battery so that we do not have to use the robot controller and radio to turn the motor on/off?
Unread 13-01-2011, 15:46
CrazyCarl461's Avatar
CrazyCarl461 CrazyCarl461 is offline
Power User
AKA: Carl Agnew
FRC #0461 (Westside Boiler Invasion)
Team Role: Coach
CrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant futureCrazyCarl461 has a brilliant future
Send a message via AIM to CrazyCarl461
Re: VEX motor w/o robot controller?
Yes it can.
Just don't use it to compete in any FIRST or VEX events.
My 2011 Build Season Blog
Resistance may be futile, but capacitance has potential!
© All content is protected by the honor system
Unread 13-01-2011, 15:57
FRC #2147
We don't plan on using the VEX motor in competition. We are using VEX materials to prototype. We don't have any Tetrix stuff yet.
Unread 13-01-2011, 16:04
Power User
AKA: Carl Agnew
Team Role: Coach
So.. are you asking how to do it, then?
Unread 13-01-2011, 15:58
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I've thought very vaguely about how minibots can be designed - simply put, our team is holding off on that for now in order to ensure the Robot has a solid design and will be finished on time.
However, reading this made me go look at the rules, and they raise an interesting question..
There's nothing in the MINIBOT section specifically that would prevent this. However, it would appear that <R48> applies:
<R48> All electrical loads (motors, actuators, compressors) must be supplied by an approved power regulating device (speed controller, relay module, or Digital Sidecar PWM port) that is controlled by the cRIO-FRC on the ROBOT.
ROBOT – the composite electromechanical assembly designed and built by a FRC team to perform specific tasks when competing in the 2011 competition LogoMotion. The ROBOT must include all the basic systems required to be an active participant in the game – power, communications, control, mobility, and actuation. The ROBOT implementation must obviously follow a design approach intended to play the 2011 FRC game (e.g. a box of unassembled parts placed on the FIELD, or a ROBOT designed to play a different game, would not satisfy this definition). The ROBOT includes both the HOSTBOT and the MINIBOT (ROBOT = HOSTBOT + MINIBOT).
So... from this combination of rules and definition, it would appear that the minibot has to be controlled from the cRio? But that goes directly against:
<G19> After DEPLOYMENT, MINIBOTS must remain completely autonomous. Violation: The TOWER on which the MINIBOT is DEPLOYED is diabled. If the MINIBOT is not deployed on a TOWER, then the ALLIANCE’s TOWER upon which the highest RACE SCORE was earned will be discounted.
I think this might be a good question for the GDC to clarify...
Unread 13-01-2011, 16:05
FRC #2147
Yes..how?
Maybe I should have been more clear. We are using VEX motors for prototyping MINIbots designs. We will NOT use them in competition we are only testing ideas.
We have tried stripping the wires from the VEX motor (PWM connection) and tried directly connecting them to the battery. BUT the motor does not spin. We have tried ever combination of wire colors possible.
Unread 13-01-2011, 17:21
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Team Role: Teacher
Those wires go to a circuit board inside. One is power, one is ground, and one is PWM signal. If the circuit receives no PWM signal, it will not command the motor to move. If you want to just straight up power the motor, you need to open it, disregard the circuit board, and solder wires directly to the motor inside.
Also, your "hey let's just try hooking up these wires" approach to problem solving frightens me. I don't know what battery you're using, but please be aware of the safety considerations involved in doing such a thing. Your approach could lead to a deadly situation given different circumstances, say, 120VAC instead of low voltage DC. Have the patience to learn what you are doing from someone who already has.
Unread 13-01-2011, 17:49
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
Eagle,
The robot rules have been slightly modified by Team Update #1 and only the two sections at the end of the manual apply to the minibot. R48 does not apply to the minibot for instance.
Grosh, I hope you haven't killed the VEX motor. You are lucky you haven't burned yourself or damaged the battery. Do some research first, then make an informed decision on how to hook something up.
Al
WB9UVJ
www.wildstang.org
________________________
Unread 13-01-2011, 18:04
Originally Posted by Al Skierkiewicz View Post
Eagle,
That's definitely good news... but reading the update I don't come away with that impression. The definition of ROBOT was updated, but it still says "ROBOT = HOSTBOT + MINIBOT", and rules like R48 still say they apply to the ROBOT, not just the hostbot...
Granted, I think the intent for the game is clear, made even more so by the demonstrations at kickoff... but the wording of the rules still doesn't seem to make that distinction clear.
Unread 13-01-2011, 19:14
Unsung FIRST Hero
Rookie Year: 1996
Eagle,
I will check and get back to you.
Grosh,
The 9.6 volt battery is 1000maHr and 7.2 volt battery is 3000 maHr. Either can produce fire if misused and under certain conditions can produce burns, and explosive release of gases generated within the battery. Either of these batteries when fully charged is capable of several tens of amps into a short. A standard nine volt battery is about 500 maHr but can't source nearly the current that NiCd or NiMH technologies can.
Al
WB9UVJ
www.wildstang.org
Unread 13-01-2011, 19:30
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
Team Role: Coach
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Do you have the new 2 wire motor 269s or 393s? They are both already wired for 2 wire use and come with their mini gear boxes. - The 2 wire motors were designed so future VEX teams could possibly make their own custom circuits.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 13-01-2011, 17:55
FRC #2147
Talking Re: VEX motor w/o robot controller?
Thanks for the advice. We are well aware of the dangers of plugging in wires to a wall socket. The standard VEX battery is 9V when fully charged. Don't know the exact amperage but we have tested it by putting our tongue between the pos/neg leads.
