denso window motor limit?
Is there a limit on denso window motors for this season. I looked in the rule manual and couldnt find a limit and just want to make sure thankss for your help
Re: denso window motor limit?
Read <R46>. Then read <R45>.
i have alread read those but i am still slightly unclear the densos are not listed but they are not prohibited so am i to assume that we are allowed to use them?
<R46-A>. Read it again. Then read <R45-A> again.
Or instead of being condescending you could help clear up his confusion...
R45A states that you can use all motors included in the Kit of Parts. R46A states that you cannot use any motors that are different or in addition to what is in the Kit of Parts, excluding the exceptions listed in R45. Therefore you need to check the Kit of Parts checklist for the full motor listing. From there you will see that you can use the following window motors: 2 - Window Motor Left, P/N: 262100-3040 2 - Window Motor Right, P/N: 262100-3030 So four total, max of two of each type. Hope this helps and good luck with your rookie season. Last edited by Karthik : 13-01-2011 at 18:34. |
With the exceptions mentioned for CIM and Banebots motors in mind, you may only otherwise use what is provided in your KoP -- 2 left-hand and 2 right-hand window motors.
Please read the rules. Please stop being so pedantic about telling people to read the rules. |
