Go to Post Ah, free slave labor. One of the many benefits of being a mentor - Ari423 [more]
Unread 13-01-2011, 19:02
All Bones's Avatar
All Bones All Bones is offline
FRC #0302
All Bones is an unknown quantity at this point
Claw ideas (particularly materials and such)
Alright, I've done most of the conceptual designs for the claw of our bot to grab the tubes this year and I've figured out a few things.
1. Optimal space in between the claw should be about 6.25 inches
2. The bottom part of the claw only has to be as long as the height of the tube(s)
3. Being able to hook under the tube then rotate the claw at the point where it meets the arm until it is above the tube and perpendicular to the tube will make it arguably easy(ier) to pick up tubes. Or you could just keep the claw pointed down as you drive but that would be boring.
And
4. Rubber bands and wood can easily grab the tubes by themselves if used with the 6.25" gap and step 2, so obviously not much power is needed
However we can't build a functional claw (well maybe functional but probably not practical) out of wood for the competition. What I was thinking was, where the two parts of the claw meet, it would be optimal to keep the bottom most part non-movable and put some kind of gear teeth on the inside edge of the top part, still where the claw meets the arm. Then just use a servo to spin a gear that will close the top part of the claw. We were also considering adding extra space to the top part in order to put in a kind of roller to manipulate the tubes vertically. Other then all that though, I'm not sure how to build it. Like what materials to use or how to attach it to the arm (which is not fully designed yet so please don't ask anything regarding that). Any suggestions would be appreciated.
Someday someone on a robotics team is going to see a button and not have any idea what it does, press it, and destroy the world. And that's how technology will kill us all
Unread 13-01-2011, 19:15
Bob Steele's Avatar
Bob Steele Bob Steele is online now
On the RIBMEATS bandwagon....
AKA: Bob Steele
FRC #1983 (Skunk Works Robotics)
Team Role: Coach
Bob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond reputeBob Steele has a reputation beyond repute
Re: Claw ideas (particularly materials and such)
i might suggest that a fairly simple way to create a thicker jaw is to use two pieces of polycarbonate or aluminum or something fairly thin cut to the size you need. You can join them with spacers (or standoffs if you have them) this can make a nice thick creation out of a two dimensional piece.
it is kind of like extruding in inventor if you use that or any 3d program... the extrusion size is determined by the length of the spacers between... (held on by screws through the two "plates")
This method can really make something quickly and cheaply...and it is quite robust.
i wouldn't rule out a wooden jaw though... I don't see any reason that you couldn't make a jaw out of wood though... Remember that plywood is one of the first composites!!
I have seen many great designs done in wood... if you understand and use its properties and can deal with the weight to strength issues... it is a fine robot material...
We made a gripper in 2007 in the way I described above ... with the standoffs and polycarbonate... and used some simple aluminum bar stock for linkage and it worked great...
Good luck!!!
Raisbeck Aviation High School TEAM 1983 - Seattle, Washington
Las Vegas 07 WINNER w/ 1425/254...Seattle 08 WINNER w/ 2046/949.. Oregon 09 WINNER w/1318/2635..SEA 10 RCA ..Spokane 12 WINNER w/2122/4082 and RCA...Central Wa 13 WINNER w/1425/753..Seattle 13 WINNER w/948/492 & RCA ..Spokane 13 WINNER w/2471/4125.. Spokane 14 - DCA --Auburn 14 - WINNER w/1318/4960..District CMP 14 WINNER w/1318/2907, District CMA.. CMP 14 Newton Finalist w 971/341/3147 ... Auburn Mountainview 15 WINNER w/1318/3049 - Mt Vernon 15 WINNER w/1318/4654 - Philomath 15 WINNER w/955/847 -District CMP 15 WINNER w/955/2930 & District CMA -CMP Newton -Industrial Design Award
Unread 13-01-2011, 19:38
All Bones's Avatar
FRC #0302
Awesome, thanks. We managed to find the bottom part of our 2007 claw which was made pretty much the same way you just described, with two pieces seperated by . . . something, i wasn't on the team then, so I don't know. But it seems like this idea is going to come along nicely
