Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 13-01-2011, 19:56
tomy tomy is offline
FRC #3038 (I.C.E. Robotics)
tomy has a spectacular aura abouttomy has a spectacular aura about
D-Link set up
so i was setting up the wireless new d-link router and following these instructions:
http://www.usfirst.org/uploadedFiles...Your_Radio.pdf
and we got to the part about going to the wireless tab
we click on the wrieless network settings and we get a blank screen
anyone got any suggestions?
and yes we tried restarting it multiple times
Unread 13-01-2011, 20:01
tutkows1's Avatar
tutkows1 tutkows1 is offline
FRC #2077
tutkows1 is an unknown quantity at this point
Re: D-Link set up
When you restarted it, did you turn it on or off or refresh?
Did you save any settings before hand?
If you already changed your IP, you will need to connect to 10.xx.yy.1 not the default.
xx being the first two numbers of your team number, yy being the last.
Unread 13-01-2011, 20:04
Re: D-Link set up
you were supposed to reset it not restart it
Unread 13-01-2011, 20:05
iblis432 iblis432 is offline
Co Captain/Chief Programmer
AKA: Bobby
FRC #2106 (Junkyard Dogs)
iblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to beholdiblis432 is a splendid one to behold
Re: D-Link set up
You HAVE to use internet explorer like in the manual. We had the same problem with Firefox, we thought about how some websites don't load in certain browsers so on a whim we switched to internet explorer and everything loaded.
"Don't worry, programming can fix it"
Unread 13-01-2011, 20:06
tutkows1's Avatar
FRC #2077
Re: D-Link set up
I'd try opening the page from another computer if possible.
Edit:
Thats interesting, that firefox doesn't work. I used chrome and it worked fine
Unread 13-01-2011, 20:07
Re: D-Link set up
im using chrome and i got nothing
Unread 13-01-2011, 20:11
AKA: Bobby
Re: D-Link set up
Make sure you have it switched to Bridge, I found that the switch can set sometimes in between two settings and pages load funny
