#16
Re: paper: Simple Motor Calculator
For example, at the rated voltage and for a given torque tau, you can find the speed as follows: speed = free_speed*(1-tau/stall_tau) some of the other calculations, for example solving for efficiency or finding voltage when given rpm and torque, are a bit trickier, but not too bad. I'm glad you discovered it and hope you find it helpful. |
#17
Ether == Awesome - any chance you'll part with the source so I can compile a Linux version?
TIA |
#18
I'll pull out the formulas and post them. Give me a couple of days. |
#19
If it was a windows console app, it will probably just compile and run quickly with minor changes. You can send the source if you want.
#21
Thanks anyways. |
#22
Of course. I thought you were after some of the more arcane calculations, like solving for operating range given operating volts and desired minimum efficiency*. I've never seen that published anywhere.
Anyway, unless you have an old copy of Kylix the source wouldn't serve the purpose intended. Oh well, the equations are out there for anyone who might be interested. *it's not as useful as other calculations, I know, but I included it because it's interesting to play around with and may provide some insight |
#23
Well, it just so happens that I do ... BTW, FIRST Team 1296 very much appreciates all the great advice you regularly disperse on CD!
#24
There have been a number of occasions recently where I wanted to calculate a motor's applied voltage given rpm and amps. To make this more convenient I added another option to the motor calculator. I have also changed the display to show waste heat watts instead of input watts, since that seems to be of somewhat more interest. Input watts is easily calculated by adding output watts and waste watts. |
#25
The new version (MCALC_2013b) is at the bottom of the list of attachments. |
#27
Motor Calculator has just been updated to include all 2014 motors. Sorry for the delay. Better late than never :-) http://www.chiefdelphi.com/media/papers/2432 |
#28
Motor Calculator has just been updated to include am-2161 & am-2194 motors (for am-0914, 2193, & 0915 gearmotors) http://www.chiefdelphi.com/media/papers/2432 |
#29
Thanks again Ether!! You would not believe how much we use this utility.
#30
THAT IS SWEET AND USEFUL
