Go to Post While youth is wasted on the young, in FRC knowledge can be wasted on those a bit older. - IKE [more]
Unread 14-01-2011, 13:36
dirkpower90 dirkpower90 is offline
FRC #0437
dirkpower90 is an unknown quantity at this point
First Signal Light
we are trying to wire the signal light to the digital sidecar, what connector do we use to wire it up?
Team 437
Unread 14-01-2011, 13:41
KyleWishnok's Avatar
KyleWishnok KyleWishnok is offline
FRC #2544 (HCRC)
Team Role: Driver
KyleWishnok will become famous soon enough
Re: First Signal Light
we used one of the 2 wire jumper wires. all you do is cut one of the ends off run the posivive side to both La and Lb and the negative to N. then it plugs into the port right next to the power on the sidecar,
hope this is helpful. if you have anything else feel free to ask
