Go to Post Don't fight bureaucratic morons... embrace them! Humour and publicity will take care of the rest. - dtengineering [more]
Unread 14-01-2011, 18:28
pavanetti's Avatar
pavanetti pavanetti is offline
FRC #1382
pavanetti is an unknown quantity at this point
Exclamation Using AxisCamera in labview dashboard with a java programming
My team is programming in java. We want to see a camera image in the labview dashboard.
In java, we want to use addInt, addByte, addFloat, addArray, addCluster. But we can't convert a Image to a basic type. Does anyone know how I send the images to the dashboard in java?
And I found an alternative dashboard. It's called ZomB. But I don't know if it allowed its use in competitions. There's nothing in the rules.
And this dashboard asks to modify some files from cRIO. It says it can corrupt the file ni-rt.ini. Can I connect via FTP with the cRIO and make a backup of files? Someone recommended me to try this ZomB or should I try to labview.
Unread 14-01-2011, 18:34
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
Re: Using AxisCamera in labview dashboard with a java programming
1. No rules against ZomB.
2. In LabVIEW, on the Dashboard, there is a VI called "Get Image on PC" which does exactly that - it gets an image on the Dashboard. The cRio forwards the camera to the dashboard automatically, and you can get that image on the Dashboard.
2b. Last year, the camera code indicated what it was looking at by applying circles to the Dashboard image (using IMAQ Overlay), and sending the circle coordinates over the Dashboard data stream.
Kettering Motorsports
Unread 14-01-2011, 20:10
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Being the ZomB creator, I may be a bit biased, but please try ZomB (0.7 is amazing compared to 0.6)
Legality: DBPacket is 100% legal, TCP (the default) is pending a decision from the GDC, but should be legal, considering what they have said in the past. Both are always available at home, and the TCP sending TO the robot is really nice for lots of variables needing tuning.
As for corrupting the ni-rt.ini, I've tested it, and it has not corrupted mine, but I would back it up (ftp://10.xx.yy.2/ xxyy is your team number), run the installer, and compare the new ni-rt.ini (it also saves a backup), and make sure it only added ZomB.out to the StartupDLls list. If not, either manually edit it, or replace it with the backup it automatically creates (ni-rt.ini.backupTIMESTAMP). you can also manually install it
If you have any questions, please ask!
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
