Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 15-01-2011, 05:25
Kohala2460's Avatar
Kohala2460 Kohala2460 is offline
AKA: Michael
FRC #2460 (Na Paniolo)
Kohala2460 is an unknown quantity at this point
Question Unplugable controller?
Would it be possible to have an unplugged custom control behind the game lines during autonomous then have it be plugged in as soon as driver control started?
Unread 15-01-2011, 05:49
ttakashima's Avatar
ttakashima ttakashima is offline
T^2
AKA: Travis
FRC #2504 (The Governors)
Team Role: Coach
ttakashima has a spectacular aura aboutttakashima has a spectacular aura about
Re: Unplugable controller?
Do you mean the driver box lines? If you do, why not just add the custom control box to your DS board?
However this rule "<G14> Any control devices worn or held by the DRIVERS must be disconnected from the OPERATOR CONSOLE, and not connected until after the AUTONOMOUS PERIOD." allows you to plug it in after operator control has started.
Travis Takashima
Team Leader: Team 4270 - 2016-beyond
Mentor and Team Leader: Team 2504 - 2009-2016
Team 2504 Alum 09'
Attending
-FIRST BAE Systems Hawaii Regional
Unread 17-01-2011, 02:00
nitneylion452's Avatar
nitneylion452 nitneylion452 is offline
AKA: Joe Lee
FRC #3167 (Environmental Tectonics Crusaders)
Rookie Year: 2010
nitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud ofnitneylion452 has much to be proud of
I wouldn't recommend doing that because the Classmate may not pick up the controller unless it is restarted. My team has had this problem before where a joystick would come out and when we plugged it back in, the PC didn't recognize it until we restarted it.
Unread 17-01-2011, 10:21
DonRotolo's Avatar
Back to humble
FRC #0832
In any case, USB takes some time to recognize and manage a newly connected device. Is it wise to wait 15 seconds after teleop begins to be able to control your robot?
Unread 17-01-2011, 10:40
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
If the custom controller box connects to the Cypress PSoC, you won't have any USB reconnection delay to worry about when it gets plugged in.
Unread 17-01-2011, 23:35
Kohala2460's Avatar
AKA: Michael
thank you alan
