Go to Post My experience in FIRST has taught me that, whatever you do, make sure that no single failure can eliminate half your drive system.[...] The worst feeling in the world is having your robot driving around in circles when there is critical business to be done on the playing field. - Andrew [more]
Unread 15-01-2011, 11:29
oliveryasuna oliveryasuna is offline
FRC #2076
oliveryasuna is an unknown quantity at this point
Configuring the cRIO?
Okay, so I am trying to reconfigure the cRIO so we can deploy our LabVIEW project onto the robot, and have it stay there.
When I try to format the controller I get this error:
"The imaging tool has detected that you have a CAN Plugin enabled and you have an old image installed. Your CompactRIO would hang when trying to reboot. Please remove the CAN plugin from the StartupDlls line in ni-rt.ini and then manually reboot your CompactRIO before trying again."
Can anyone help? Thanks!
