2011 cRIO image Help
Hello we are currently trying to image our cRIO with the current 2011 image. While applying this update we have run into the following error
Unable to complete operation because of unexpected error 60: UDP Open in repFPC open connection.vi->SendRebootCmd.vi->RebootSystem.vi->Format Target.vi->ConfigUtility.lvlib:ReImageTarget.vi->ConfigUtility.lvlib ialog.viWe have tried formatting the cRIO but the error persists. Any help is apprieciated |
Re: 2011 cRIO image Help
That usually means there is some network trouble between your laptop and the cRIO. Often it's not a connectivity problem, but just bad timing.
Simply trying it from a different computer sometimes works. You can try hooking the two (cRIO and laptop) together different ways
