Go to Post anything that breaks a kitbot frame is probably breaking most custom frames of similar weight, too. - dtengineering [more]
Unread 15-01-2011, 12:41
team2491 team2491 is offline
FRC #2491
team2491 is an unknown quantity at this point
Jaguar with multiple motors
<R48> says "each CIM motor ... must be connected to one and only one approved speed controller." Is it okay to use one controller to run multiple CIMs, though?
Unread 15-01-2011, 12:47
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Jaguar with multiple motors
No. <R41> specifically bans multiple loads on one power-regulating device, with an exception for low-load solenoid valves on a relay module.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 15-01-2011, 14:05
Bmarquez Bmarquez is offline
FRC #3143 (Extreme Exotic Fire Breathing Rubber Duckies)
Team Role: Leadership
Rookie Year: 2010
Bmarquez is an unknown quantity at this point
It sounds like you are just trying to get 2 motors to run in sync, which can be done easily with 2 jaguars or Victor speed controllers. this can be achieved by running a Y cable from the signal bus to the 2 speed controllers. This can also be solved by programming both signals to be triggered to go off at the same time.
Unread 16-01-2011, 11:09
Jim Meyer's Avatar
Jim Meyer Jim Meyer is offline
Engineering Mentor
None #0067 (HOT)
Rookie Year: 2000
Jim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond reputeJim Meyer has a reputation beyond repute
I really wish they would let us connect two low power motors to the same speed controller (like two window motors) to save on cost and complexity. They used to let us do it, but sadly is against the rules now.
Unread 17-01-2011, 11:21
dyanoshak dyanoshak is offline
AKA: David Yanoshak
FRC #2158 (ausTIN CANs)
Rookie Year: 2007
dyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond reputedyanoshak has a reputation beyond repute
The Jaguar has a useful Sync feature that allows you synchronize multiple Jaguars to one Sync command. This feature is only available if you are using CAN to communicate with the Jaguars.
For example, you might have two motors for your drivetrain, one for each side, and you want them to start moving in unison. Using the Sync command you can set the voltage output of both Jaguars, but keep them from updating the until they receive the Sync command again.
This can be easily demonstrated using BDC-COMM and a couple of Jaguars on the CAN bus.
  1. Go to Voltage mode and press the Sync button.
  2. Change the voltage for a couple of Jaguars.
  3. Notice that the Jaguars maintain their current output setting.
  4. Now press the Sync button again and watch the Jaguars change in unison.
-David
