Go to Post We do a disservice as mentors if we simply complain. We must inspire our students by showing them how we rise to the challenge and solve the problems we face. - Jon236 [more]
Unread 15-01-2011, 15:28
Da Kid's Avatar
Da Kid Da Kid is offline
FRC #2957
Da Kid is an unknown quantity at this point
Photosensor wire gauges
What gauge wires should we use to connect the sensors to the power distribution board. and does it need to be the white wire or can you use the black and red wires also so i don't use up all of our pwm cables? i know there is the other thread about wiring the photo switches but i couldn't find wire gauges anywhere.
Unread 15-01-2011, 16:16
otherguy's Avatar
otherguy otherguy is offline
sparkE
AKA: James
FRC #2168 (The Aluminum Falcons)
otherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to beholdotherguy is a splendid one to behold
Re: Photosensor wire gauges
For the PD wiring:
Although the photosensor isn't specifically called out I believe it would fall under <R39> (F) and require a 20AMP breaker.
<R40> defines wire sizes based on breaker sizes.
20AMP --> 18AWG minimum
I don't know the answer to your 2nd question. I'm not aware of any rules requiring a specific wire color to be used for the signal on the PWM lines.
Unread 16-01-2011, 15:32
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
For wiring power to it, use 18 gauge black and red wire. (red/black zip cord is my favorite, but feel free to use what you have)
For signal, I would recommend white or green. Here you can use any color, so long as you won't confuse it with power. 24 or 26 guage is common, but you can use a range from 22 -28. (30 is too small; it will break easily. 20 is too large to fit into the PWM crimps)
-- Marshal Horn
Unread 17-01-2011, 08:59
Unsung FIRST Hero
AKA: Big Al WFFA 2005
FRC #0111 (WildStang)
Rookie Year: 1996
I recommend you use #18 from the PD to a point where you splice all the sensor power wiring together, either using typical wire splice techniques or a terminal strip like the one you received in the KOP.
Al
WB9UVJ
www.wildstang.org
________________________
