Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 16-01-2011, 16:08
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
Team Role: Coach
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Mecanum Advice Request
We are considering having mecanum this year and were wondering what the subtleties of it are. Anything and everything would be helpful such as what gear boxes to avoid, what ratios would be best or various problems with programing.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 16-01-2011, 16:12
Duke461's Avatar
Duke461 Duke461 is offline
Boiler Strong.
AKA: Ben Carson
FRC #0461 (Westside Boiler Invasion)
Rookie Year: 2010
Duke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond reputeDuke461 has a reputation beyond repute
Re: Mecanum Advice Request
This is our (461) second year in a row that we are using mecanum; i don't know a whole lot about it, but i do know that:
Much better maneuverability
Less pushing force
Harder to program/longer
Problems can occur with a direct drive setup and thoughbox nanos, because it pushes the bearings with a force and direction they're not designed to take.
But all in all, if you're programmers and drivers are up for it, it is a great choice
The opposite of excellence is good enough.
2012-2013 President; 2011-2012 Vice President
2011-offseason FRC Student Drive Coach; 2010-11, 2011-2012 VEX Drive Coach
2011, 2010-offseason FRC Driver/Operator
2012, 2011-offseason, 2010-offseason FRC Human Player
Find me on: Facebook, Gmail, Twitter, Tumblr, Blogger/Blogspot
Unread 16-01-2011, 16:21
jblay's Avatar
AKA: Joe Blay
Team Role: Coach
We were considering using the nanos. Have you tried using them? What went wrong if you did?
Unread 16-01-2011, 16:23
Chris is me's Avatar
AKA: Pinecone
I've heard good things about direct drive + Toughbox Nanos in mecanum drives, as well as regular Toughboxes.
Unread 16-01-2011, 16:26
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Rookie Year: 2010
Well, we haven't tested them out yet, but the mentors noticed that the bearings might not be able to take the 45 degree angle load from the direct mecanum drive, at least for the nanos. we aren't 100% sure yet, but it's definitely something to look into
Unread 16-01-2011, 16:45
Dracon Phinex's Avatar
Dracon Phinex Dracon Phinex is offline
AKA: Daniel Wright
FRC #3130 (ERRORs)
Team Role: Team Spirit / Cheering
Rookie Year: 2010
Dracon Phinex is an unknown quantity at this point
If you want an agile bot, go ahead. The team I'm with wanted to do mecanum wheels, but decided not to because of programing issues tied up in it. The ideas are great, but are not very good for newer teams. The frame might have to modified in order to do this.
Unread 16-01-2011, 18:43
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Dad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud ofDad1279 has much to be proud of
Last year 1279 used 8" mecanums, direct drive to long output shaft nanos, 12.5:1. We used a bearing on the other side of the long shaft.
My suggestion is get it done ASAP, so the driver(s) have time to train, and programers have time to program it. We actually built a test bot using a second set of Mecanums, using a 3/4" plywood base fot driver training and programming.
Unread 16-01-2011, 19:13
jblay's Avatar
AKA: Joe Blay
Team Role: Coach
We are planning to do the same thing except with a legit second drivetrain.
Our plan is to use the 6 inch mecanum. Is the 8.45:1 ratio to slow? I know that mecanum is inefficient and will lose some of that speed but how much?
Unread 16-01-2011, 19:19
AKA: Pinecone
Nope. For reference, 12.75:1 with 6" wheels is ~9 feet per second.
Unread 16-01-2011, 20:02
BigJ BigJ is offline
AKA: Josh P.
FRC #1675 (Ultimate Protection Squad)
Rookie Year: 2007
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
If you have an algorithm that translates in every direction the same, you will get about 71% ( sqrt(2)) of full power from your motors when going forward with no other modifications. 1675 usually includes a "beast mode" for going stright forward/back with 100% power.
Unread 16-01-2011, 20:10
Duke461's Avatar
Boiler Strong.
AKA: Ben Carson
Rookie Year: 2010
Going on the topic of bearings, and this might sound like a stupid question, are spherical bearings ever used (as opposed to the traditional ball bearings)? and if so, what are the pros and cons respectively?
thanks
-duke
Unread 16-01-2011, 20:11
Jogo Jogo is offline
FRC #0353 (Pobots)
Rookie Year: 2007
Jogo is on a distinguished road
Can you further explain this? Why would you only get 71% when going forward?
Unread 16-01-2011, 21:31
AKA: Josh P.
Rookie Year: 2007
Not sure how much you know overall about Mecanum so I'll lay it all out.
Mecanum wheels produce a force at a 45% angle when driven. The x and y components respectively equate to roughly 71~% of the total vector. (Actually thinking about it my sqrt(2) comment makes no sense. it's actually 1/sqrt(2) for each side. 1/1.414 ~= .71)
In my head, without looking at our algorithm it isn't making a ton of sense (since the forward vectors would be 71% too), but I know that when we're running "normally", which is translating at the same speed in every direction, our motors run at only that 71% when going forwards.
EDIT2: It is because the motor outputs in our algorithm are limited by a trigonometric function and motor offsets. It just so happens that our motor outputs when going forwards or backwards are +/- sqrt(2)/2, which is the same ~71%.
We give the drivers the option to drive our motors at 100% forward/backward.
Unread 16-01-2011, 22:00
Ether's Avatar
Ether Ether is offline
systems engineer (retired)
Rookie Year: 1969
If you use the provided library functions (such as LabVIEW Holonomic vi), you don't have to worry about this and there is no need for a "beast mode", because the normalization is performed on the wheel speeds after the inverse kinematic calculations are performed, not on the joystick commands. You get the full range of motor command to the wheels in all directions.
Now, don't confuse this with the pushing force of a mecanum, which is a separate issue. In a traction-limited situation, mecanum has less pushing force than a standard-wheel vehicle using the same tread material, because the floor reaction force (for a given forward force) is higher on a mecanum wheel so it loses traction more easily.
  #15   Spotlight this post!
Unread 16-01-2011, 20:19
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Team Role: Leadership
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
If you are direct driving a mecanum drive or any drive for that manner, make sure you support the shaft in two places. If you don't you'll bend your shaft and destroy your drive train. The tough box series from andy mark does have two support points internally and you can get away with no external supports on the shaft for short distances. However if you use an extended shaft you'll just kill the gear box and the shaft if there is no support on the other end of the shaft. My team used mechanum last year and used the P80 gear boxes with an extended shaft. It was extremely efficient, had good mount points for the encoder, and we had no problems. Hope this helps
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
