Go to Post I'm not overdosed, I'm not even addicted. I just choose to never, ever, ever leave FIRST. - SL8 [more]
  #31   Spotlight this post!
Unread 17-01-2011, 14:41
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
Re: Mecanum Advice Request
Originally Posted by JonA View Post
More details of what BigJ is talking about can be found in this paper about the control strategy used by FRC Team 1675. Basically the output is limited based on the inverse kinematic calculations to allow for maximum speed output of the robot to be the same in all directions with overhead for the yaw rate to be added allowing the same yaw rate control regardless of the heading. These calculations result in the reduction of total overall maximum speed (not using the full range when traveling in the forward/reverse direction) in favor of overall normalization of speed and yaw rate. "Beast Mode" basically allows the driver to override this control decision.
As Ether noted this year the math in the provided holonomic drive VI's corrects for this already and no optimizations are required to achieve optimal drive output, though this was an issue last year.
The considerations we have mistaken before include accidentally mounting the mecanum wheels in X and not O configuration and balancing and maintaining the weight/downward force on each of the wheels.
This is something that we had trouble with the first time we used holonomic wheels also. Be careful that viewed from below your robot the rollers on your wheels form an O and not an X.
  #32   Spotlight this post!
Unread 17-01-2011, 14:47
Jogo Jogo is offline
FRC #0353 (Pobots)
Rookie Year: 2007
Jogo is on a distinguished road
Let me just try to clear this up for me and others...the rollers should form an "X" from top-view and an "O" when looking at it from below?
  #33   Spotlight this post!
Unread 17-01-2011, 14:49
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
No, the rollers should form an O either way.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
  #34   Spotlight this post!
Unread 17-01-2011, 14:51
Todd's Avatar
Software Engineer
I'm not looking at a holonomic robot right now, but I'm pretty sure that the rollers should form an O from below and an X from above.
As described here:
http://www.chiefdelphi.com/forums/sh...ad.php?t=80962
EDIT: With mecanum wheels at least, mounted parallel with the drive chassis. Omniwheels are another story.
  #35   Spotlight this post!
Unread 24-01-2011, 22:31
GearsOfFury's Avatar
GearsOfFury GearsOfFury is offline
Former guy that does stuff
AKA: Mark Anderson
GearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to beholdGearsOfFury is a splendid one to behold
If I may ask, where did you mount your encoders on the p80?
Peter - Last year, BaneBots sold a kit, EN-G0561-KT, that consisted of an optical digital encoder that could be mounted directly (glued) to the output shaft of the gearbox, with a neat plastic cover and mounting kit. It doesn't appear that they offer these any longer on their website, though. I believe they were US Digital encoders, though, so the BaneBots folks may still be able to help you locate some sets.
  #36   Spotlight this post!
Unread 24-01-2011, 22:55
pfreivald's Avatar
Thanks for that... Given BB's inability to ship anything even vaguely on time (including non-P60 stuff that wasn't notified as having any kind of delay), I think we'll figure out something for ourselves!
Team 1551
I write books, too!
  #37   Spotlight this post!
Unread 25-01-2011, 09:49
lcoreyl's Avatar
lcoreyl lcoreyl is offline
WittyTitleGen can't link to library
AKA: Milner
lcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud oflcoreyl has much to be proud of
I am looking at one, and you are correct.
Bird eye view = X , Worm eye view= O
