Go to Post Looks like we will be building a wood robot :) - IndySam [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 16-01-2011, 18:59
Ted3299 Ted3299 is offline
Team 3299 Programmer
FRC #3299 (Warehouse Crew)
Team Role: Driver
Rookie Year: 2010
Ted3299 is an unknown quantity at this point
Help adding KoP to Inventor
I'm having some trouble adding the files i downloaded from Autodesk's website to Inventor. You anyone help me out with where I should put all the extracted files?
Unread 16-01-2011, 21:39
Creator Mat Creator Mat is offline
FRC #2338 (Gear it Forward)
Team Role: Leadership
Creator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the roughCreator Mat is a jewel in the rough
Re: Help adding KoP to Inventor
Just put a folder labeled KOP inside of the folder you are saving your project. I keep all the sub folder hierarchy but you don't have to if you don't want to.
2010 Midwest Spirit award
2010 Midwest Quarterfinalists
2010 Wisconsin Quarterfinalists
2009 Midwest Finalists
2009 Wisconsin Quarterfinalists
2008 Midwest Rookie AllStars
Unread 16-01-2011, 21:57
bstrong1218's Avatar
bstrong1218 bstrong1218 is offline
Brandon
AKA: Brandon
FRC #3344 (Robocopz)
Team Role: Mechanical
Rookie Year: 2010
bstrong1218 is an unknown quantity at this point
No idea how/if you're planning to share files, but be sure to create a project file. My team is in its second year and a few of us decided to use Inventor to model a couple basic parts. We've been sharing files through Dropbox, but recently discovered that w/o a project file Inventor seems to want an absolute instead of relative file path. Maybe somebody can confirm this or has a better suggestion for file sharing.
Is there a way to add the KoP to Content Center? Once again, I'm new to Inventor, but it seems like there's advantages to having the parts in Content Center. For example, adding chain seems like it can only be done with Inventor's built-in library unless you want to put each link together that comes in the KoP.
Unread 24-01-2011, 18:41
Daniel_H's Avatar
Daniel_H Daniel_H is offline
FRC #1156 (Under Control)
Daniel_H is just really niceDaniel_H is just really niceDaniel_H is just really niceDaniel_H is just really nice
Where exactly is the KoP in Autodesk webpage?
I couldn't find it
[<o>] gogogo [<o>]
http://undercontrol1156.com/
Unread 28-01-2011, 14:12
inventor_phild inventor_phild is offline
inventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant futureinventor_phild has a brilliant future
I couldn't find it
It is located here.
http://students.autodesk.com/?nd=kit...lter=&x=38&y=9
Phil Dollan
Autodesk Inc.
Autodesk Inventor and Fusion 360
Unread 06-02-2011, 16:30
RogerHebert's Avatar
RogerHebert RogerHebert is offline
FRC #0811 (Cardinals)
RogerHebert is on a distinguished road
Thanks for the link. However, when I click it, it asks me to login. After I do, it brings me to another login window. I log in again, then it tells me I'm already logged in.I click Continue, to stay logged in, whereupon it brings me back to another log in window... arrrgh...
Roger Hebert
Mentor, Team 811 *The Cardinals*
FIRST - The answer to the question: "What's this world coming to?"
Unread 07-02-2011, 21:40
Roger,
Contact me directly and lets see if can help you resolve this.
Phil Dollan
Autodesk Inc.
Unread 09-02-2011, 18:08
Originally Posted by inventor_phild View Post
Roger,
Thanks. What's the best way to contact you?
Roger Hebert
Unread 07-02-2011, 22:43
BIG Dakota's Avatar
BIG Dakota BIG Dakota is offline
FRC #1730
BIG Dakota is an unknown quantity at this point
Im having the same problem
