Go to Post There are so much more things to be worked on and are more beneficial to FIRST and FIRSTers than green dots by someone's name. - tiffany34990 [more]
Unread 17-01-2011, 00:21
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Safe Torque Limits for BB P60 Planetaries
It appears that Banebots doesn't publish any sort of torque limits for the P60 planetaries. I know (have experienced ) that cantilevering the output shaft can lead to bad things rather quickly. How much torque have you teams extracted from them without issue when they were properly installed?
I found an old thread where Dr. Joe said that the old 42mm would fail under cycled loadings of about 350 in*lbs. Would that be a reasonable guideline to design under (obviously while incorporating a factor of safety that lets us sleep at night). As I understand it, there has been some improvements to these gearboxes over the years?
I know the good idea is to go as low as you can go, but BB are pretty cheap and very easy to use, but I don't want to spend a season replacing them.
Thanks!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
