Go to Post Its great for us as mentors to see students teaching other students and a robot being built from scratch without us. Maybe someday they won't need us at all!!! - DR3381 [more]
Unread 17-01-2011, 00:50
noa_n_f noa_n_f is offline
FRC #1378
noa_n_f is an unknown quantity at this point
RS775 Gearboxes
It seems strange that banebots wouldn't have these available by now.
I'm looking to use four S775 to lift a ten pound arm thats about 60 inches long. Is this overkill, or would it allow me to maximize the speed of raising and lowering the arm?
Any suggestions for a gear ratio/gearbox and where I might be able to get it? The goal is to turn all four output shafts from the banebots motors into a single pivot to move the arm.
Thks in advance!
Unread 17-01-2011, 01:07
rahilm's Avatar
rahilm rahilm is online now
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: RS775 Gearboxes
Thks in advance!
I conacted Banebots about this and they said they expect them to be up Monday or Tuesday.
I think 4 will be complete overkill. Our calculations allow us to lift an arm double the size and weight (i.e. 4x torque), running them at only 1/4 of their stall torque with just 2 motors.
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 17-01-2011, 01:26
Chris is me's Avatar
AKA: Pinecone
Re: RS775 Gearboxes
4 is complete overkill. They're roughly 240W motors if I recall correctly - think the equivalent of a 2010 FP motor.
Unread 17-01-2011, 01:30
pfreivald's Avatar
pfreivald pfreivald is offline
AKA: Patrick Freivald
FRC #1551 (The Grapes of Wrath)
pfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond reputepfreivald has a reputation beyond repute
Re: RS775 Gearboxes
I think we're going to get away with one for our lift...
Then again, we might just use the FP.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
Bausch & Lomb, PTC Corporation, and Naples High School
I write books, too!
Unread 17-01-2011, 01:51
FRC #1378
Re: RS775 Gearboxes
Thanks for the fast responses. If I go for two RS775, what typ of gear ratios should I be looking for? It will be a parallel lift with a diagonal surgical tubing assist. I'm looking to making the arm raise and lower as quickly as possible without worrying about the motors not being able to handle it.
Unread 17-01-2011, 02:14
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Re: RS775 Gearboxes
~390 if I did my math correctly; ~(voltage)*(stall current)/4 = (12)*(130)/4 = 390 (not factoring in motor inefficiency)
Also, the 2010 FPs had roughly 190w. This year's have 290w. (Both figures from the FIRST motor curves)
The reduction we're going with is a 512:1 (256:1 with banebots gearbox, and then 2:1 with sprocket). This gives us ~576 lb-ft of torque if you go with 65% gearbox efficiency, which is more than enough to lift it, while we still have 25RPM, which is 150deg/s.
Unread 17-01-2011, 03:05
AKA: Pinecone
Re: RS775 Gearboxes
I think you took the stall current at 18 volts instead of 12 volts.
Unread 17-01-2011, 10:31
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Rookie Year: 1998
Re: RS775 Gearboxes
DON'T DO THIS. That is, unless you've carefully considered the following.
Banebots suggests a maximum torque output of 85 ft-lbs for the P80 CIM gearbox. If your mechanism is actually going to require anything close to 576 ft-lbs of torque, you'd destroy a P80 gearbox rather quickly. And P80s are tougher than the P60, which is smaller with an aluminum ring gear. BB doesn't list the max recommended torque for the P60s, but it's going to be less. At least half, possibly a quarter. So I strongly urge you to look at the maximum safe output of your gearbox and make sure you plan your gear reductions accordingly. You may want to decrease the reduction in your gearbox and add an additional reduction stage of sprockets. 256:1 gear reductions provide surprisingly little torque once the gears have failed.
Unread 17-01-2011, 11:42
AKA: Pinecone
Re: RS775 Gearboxes
I was under the impression that the P60s were counterintuitively stronger than the P80s. If the P60s can output less than 85 ft-lbs of torque, they're pretty much completely useless to me.
Unread 17-01-2011, 13:42
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Rookie Year: 1999
Tom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond reputeTom Line has a reputation beyond repute
Re: RS775 Gearboxes
Remember - if you have a 15 lb end effector at 4 feet from your pivot, that's 60 ft-lbs. If you then have a 2:1 sprocket and chain reduction leading into your P-60, then it will never seen more than 30 ft-lbs of torque statically. Dynamically is dependent on the speed you move it of course.
Unread 17-01-2011, 13:49
AKA: Pinecone
Re: RS775 Gearboxes
Yeah - this is what happens when you do math in inch pounds and are too tired to remember to convert. The gearboxes should be fine for me.
Unread 17-01-2011, 15:34
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Re: RS775 Gearboxes
Thanks for letting us know. We will probably switch to a 128:1 planetary and 4:1 sprocket in that case. At most we would need 130 lb-ft of torque to turn the arm. With 4:1 that means the gearbox should only need to put out 32.5 lb-ft of torque. That should be fine I think, but I'll ask Banebots if they have that info on the P60s.
Unread 17-01-2011, 15:45
AKA: Pinecone
Re: RS775 Gearboxes
Be sure not to just model for torque but for speed as well. An arm that rotates 180 degrees in 1 second is not very useful.
Unread 17-01-2011, 16:29
rahilm's Avatar
AKA: Rahil Mehta
Rookie Year: 2007
Re: RS775 Gearboxes
Based on our prototyping, watching some old 2007 videos, and current consensus on design, we've found that speed close to optimal. Of course, it's only week 2, and there's a lot more testing to do, so our plans may change quickly.
  #15   Spotlight this post!
Unread 17-01-2011, 16:35
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
Re: RS775 Gearboxes
Sanity check: Strap a five pound weight on the end of a 2x4 and swing that from a pivot point about five feet from the end 180 degrees in a second.
Then try to precisely place a tube on a rack with that rotation rate.
I haven't done it, so maybe I'm talking out of my butt here... but that seems pretty darn fast!
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
