Go to Post If you don't like contact, your robot is not built well enough. - sanddrag [more]
View Poll Results: Which would you chose, wedgetop or roughtop tread?
Roughtop Tread 16 72.73%
Wedgetop Tread 6 27.27%
Voters: 22. You may not vote on this poll
Unread 17-01-2011, 01:27
EagleEngineer's Avatar
EagleEngineer EagleEngineer is offline
AKA: Michael Amoun
FRC #1138 (Eagle Engineering)
EagleEngineer is an unknown quantity at this point
Wedgetop or Roughtop Tread for Wheels
What are the pros and cons for wedgetop or roughtop wheels. Which tread is better and why. Which is best for a 6WD?
Unread 17-01-2011, 01:59
klbarie's Avatar
klbarie klbarie is offline
AKA: Kyle Barie
no team (HOT Team)
klbarie is an unknown quantity at this point
Re: Wedgetop or Roughtop Tread for Wheels
where exactly do you get the tread?
2009 - 2010: Team 67-The HOT Team-Student
2011: Team 3771-The Yooper Troopers-Mentor
2012: Team 4363-The Unbolted Puppeteers-Mentor
Unread 17-01-2011, 02:54
GEARmaster08's Avatar
GEARmaster08 GEARmaster08 is offline
FRC #0876
GEARmaster08 is an unknown quantity at this point
I think what Eagle is talking about is the Andy Mark Plaction Wheels (Plastic + Traction = Plaction)
www.andymark.com/SearchResults.asp?Cat=103
Last year we (Team 876) went with the Roughtop and possibly using them again this year. We were able to go over the bumps last year with little to no problem and we were able to push other robots with pretty good success.
Here's what it looked like(http://www.chiefdelphi.com/media/photos/35059)
I think if there was sand or dirt that the robot had to drive over the Wedgetop would be the way to go, but since there is carpet, Roughtop would probably be a better choice.
Unread 17-01-2011, 07:22
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
There are a lot of sources. But we usually get the tread from Andymark, since we usually use their wheels and the tread comes pre-cut to the width of the wheel. You can also buy the wheel with the tread already installed.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 17-01-2011, 07:52
Gdeaver Gdeaver is offline
FRC #1640
Gdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond reputeGdeaver has a reputation beyond repute
You did not include a none of the above choice in the poll. Last year we used the 4" plactraction wheels and the rough top lasted better than the wedge top. we had to change the treads at least once during the competitions. This year we have found a more durable solution for treads.
Unread 17-01-2011, 09:25
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Here it lists roughtop tread having a slightly higher CoF.
Wear seems to be the same for both as they are made of similar, if not the same material.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 17-01-2011, 09:35
thefro526's Avatar
thefro526 thefro526 is offline
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
thefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond reputethefro526 has a reputation beyond repute
Send a message via AIM to thefro526 Send a message via MSN to thefro526
From my experiences with Roughtop and Wedgetop Treads from both AndyMark and IFI (Both Natural Rubber if I remember correctly) I've found that Roughtop seems to be the better of the two both in terms of grip and wear characteristics.
You can buy treads from AndyMark that are pre-cut for their wheels and the same goes for IFI.
If you've got the capabilities to cut treads, then you can buy large sections from McMaster and save a bit of money http://www.mcmaster.com/#catalog/117/1237/=amo9qe
Nice thing about McMaster is that they offer a few different tread compositions each with different wear rates and things like that. From what I've seen, Nitrile seems to wear the best (Least) with some teams being able to last an entire season without needing to retread their wheels.
-Dustin Benedict
2005-2012 - Student & Mentor FRC 816
2012-2014 - Technical Mentor, 2014 Drive Coach FRC 341
Current - Mentor FRC 2729, FRC 708
Unread 17-01-2011, 13:56
Chris is me's Avatar
AKA: Pinecone
Roughtop has gotten me better traction and wears less than wedgetop from what I've seen. Blue nitrile roughtop is the best tread I've ever seen - it never ever wears.
