Go to Post If mecanum wheels are the answer, I have found that I have asked myself the wrong question. - jwfoss [more]
Unread 17-01-2011, 12:15
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
lynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond reputelynca has a reputation beyond repute
Send a message via AIM to lynca
pic: DiscoBots Nano-killough
Unread 17-01-2011, 12:17
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: DiscoBots Nano-killough
Nice!! it looks great! I'm just curious why y'all went with the omni side of this game?
Unread 17-01-2011, 13:49
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is offline
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
Team Role: Coach
AllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond reputeAllenGregoryIV has a reputation beyond repute
Send a message via AIM to AllenGregoryIV
We did a game analysis and came to two ideas we could either build a drive train that is more powerful than other robots or we could build a robot that is more maneuverable. We also decided that speed was a crucial component in getting as many tubes hung as possible.
With that we would either need to build a six wheel drive train with a shifting gearbox or go with omni-directional and have lots of speed and be able to get around defenders quickly. We also knew that when in the our zone we will be able to position ourselves to hang without defender interference unlike 2007. Strafing in your zone to be able to get to the proper peg without exiting your zone is important so defenders can not affect you.
Swerve drive may be a better option (to have more power and still get maneuverability) but we have never prototyped swerve modules so we went with what we considered to be the best method to accomplish our game strategy that we could complete in the six weeks.
Unread 17-01-2011, 14:19
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
1745 did this type of design in 2008. it worked out well but I would suggest some sort of suspension. we found places in the carpet arnt as level as others and if all the wheels arnt applying the same pressure and traction to the floor it can mess with handling.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 24-01-2011, 15:56
J.Warsoff's Avatar
J.Warsoff J.Warsoff is offline
BECAUSE SCIENCE
AKA: Jared Warsoff
FRC #1676 (The Pascack PI-oneers)
J.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond reputeJ.Warsoff has a reputation beyond repute
that is one interesting chassis. the only thing i'm worried about is stability. it seams that without suspension, as stated above, that the robot will be very prone to tipping over. Use suspension and distribute the weight effectively, and you will have one heck of a robot there!
"I reject your reality, and substitute my own!" -Adam Savage
Check me out on Twitter or Facebook
Acoustical Engineering & Music major at the University of Hartford / Hartt School of Music Class of 2017
Unread 24-01-2011, 16:42
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Rookie Year: 2007
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Having built a robot like this last year, i woud warn again the omni drive configuration... we realized (too late in the build season) that even the smallest bump or unevenness of the playing field would cause the robot to turn violantly, no matter how much the software tries to compensate for it.
- Bochek
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 24-01-2011, 16:45
Chris is me's Avatar
AKA: Pinecone
Why would a robot without suspension be more likely to tip?
Unread 24-01-2011, 17:02
Engineering Coach
Team Role: Coach
I am not so sure what the tipping thing is about either, our chassis is 1.125" from the ground and we will have bumpers extending from that. Tipping over the bumpers will be pretty difficult.
However the traction problem is something we are definitely considering. We have several solutions in mind both mechanical and software to try to fix any problems that we might have.
Thanks for the comments and tips.
Unread 28-01-2011, 14:32
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
It won't absorb the force of a hit from another bot as well. Plus, suspension will keep it stable while maneuvering at faster speeds.
Also guys, a rookie on my team was wondering how stable this will be when you mount the other parts like the elevator, minibot/minibot deployment, etc. on it?
Unread 28-01-2011, 16:38
Engineering Coach
Team Role: Coach
Stability is something we are definitely testing. One of the things we know is that we should never be driving at high speeds with our lift up. So the vast majority of our weight besides the outer lift rails will be low to the ground when driving.
Stability is a problem every team has and our frame is the same length as most teams narror dimension.
Unread 28-01-2011, 17:41
J.Warsoff's Avatar
BECAUSE SCIENCE
AKA: Jared Warsoff
Sounds good. Here's another tip that helped my team last year: make your center of gravity very low, so put all your heavy stuff towards the bottom of the robot.
Unread 30-10-2013, 18:54
gpetilli gpetilli is offline
FRC #1559
gpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to allgpetilli is a name known to all
How did this work out for you? We are building something very similar as our off season project. This style chassis is extremely stiff and has a very low center of gravity so I doubt you had the predicted stability problems nor needed a suspension.
The major difference with ours is we went asymmetric - meaning we put the wheels at a 30deg toe-in instead of standard 60deg. This gives us more usable torque front to back (87% vs swerve) and less lateral (50% vs swerver). 45deg would give 70% vs swerve in all orthogonal directions.
Did you do robot centric or field centric controls? What sensors did you use and would you use them again?
Originally Posted by lynca View Post
Unread 30-10-2013, 19:18
Engineering Coach
Team Role: Coach
Haven't seen this thread in awhile. I was a discobots mentor when we built this robot and was in charge of the control systems team.
Was it a fun challenge, yes. Would I ever build it for competition again, NO.
You absolutely need some form of suspension or you will be struggling to get all your wheels to touch the ground at the same time. If you use driver centric instead of robot centric controls it helps alleviate some of the problems with wheels slipping. Even the smallest imperfection in the floor will make your robot turn drastically, the plates around the mini-bot poles in 2011, were a huge problem for this drivetrain. The only sensor we really used was a gyro, to keep us oriented. We had "Halo" style controls, so one joystick was for strafing and forwards and backwards and the other was for rotation. We also implemented quick position buttons on the top the turn joystick so you could quickly go to any 90 deg offset from strait ahead.
By our 2nd event, we had it working well enough for us to be the 2nd overall pick and make it the finals before losing to 118 and 1477.
Very few games allow for you to give up that much of a traction advantage and still play well.
Team 647 | Cyber Wolf Corps | Alumni | 2003-2006 | Shoemaker HS
Team 2587 | DiscoBots | Mentor | 2008-2011 | Rice University / Houston Food Bank
Team 3847 | Spectrum | Coach | 2012-20... | St Agnes Academy
LRI | Alamo Regional | 2014-20...
"Competition has been shown to be useful up to a certain point and no further, but cooperation, which is the thing we must strive for today, begins where competition leaves off." - Franklin D. Roosevelt
Unread 02-11-2013, 13:19
FRC #1559
What was the magic change that made the second event better? 2nd pick is fairly good, obviously your arm must have been great and your scoring was probably enhanced by the strafe capability.
  #15   Spotlight this post!
Unread 03-11-2013, 11:12
Engineering Coach
Team Role: Coach
Getting the drive code under control, autonomous was about 100% (we used ultrasonic sensors to get to the pegs), arm and claw control improved, minibot was drastically improved, and more driver practice.
We also increased the speed of the drivetrain by changing the gears in the tough boxes, that helped a lot.
